An awning question
Lemonhead78
I unrolled my awning for the first time this year. It was soaking wet and now has mold on it. I was thinking when I rolled it up for the winters last camping trip that it couldn't get wet at least on the inside of it . Is this a normal thing to happen or did I do something wrong?
17 REPLIES 17
austinjenna
Are you spraying just one side of the awning or both?
I just spray the underneath, dont forget this thing rolls up into itself so actually both sides come out clean.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
beemerphile1
Capillary action
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
drsteve
Griz14 wrote:
austinjenna wrote:
Unroll the awning, get it wet with the hose, spray Tilex on it and roll it back up for 30 minutes or so, unroll it and spray it off, the awning will be clean with no scrubbing involved.
Both.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
drsteve
I do the same only with bleach water (1 cup per gallon). Works like a charm.
cmcdar
Thanks OP, I too have had this issue and it is (but shouldn't) drive me crazy.
Just to be clear, I have a problem with the UNDER SIDE of the awning.
The side you see when you are sitting under it. I believe that is also what the OP is referring to.
I have tried a great many products and can never get the stains removed let alone keeping it clean.
I will try the Tilex and rolling back up to sit a spell.
HTT: 2007 R-Vision Trail Cruiser c191
TV: 2010 Nissan Titan Pro4X Crew Cab
dodge_guy
Yes normal. Store the trailer at an angle so the water will not get into and stay inside the rolled up awning. If itโ€™s longer it may also have a sag to it which makes it worse. I have a 21ft awning. I installed an awning support to keep it from sagging when rolled up.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Griz14
2012Coleman
I use Mold Armor on the awning. No scrubbing required. Spray on, let sit for a few minutes and hose off. Works great on the propane cylinder cover too. Find at Walmart, Home Depot or Lowes.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
austinjenna
Reese 16K
bobndot
Use a soft long handle brush to clean it. Do not use a pressure washer as you could damage the fabric and cause it to leak.
rbpru
When we roll up our awning and it rains, water picks up the roof dirt and seeps in the end of the awning to creates dark streaks of dirt at the bottom of each roll layer across the awning.
By spring it is usually a bit moldy so I scrub it, let it dry, then roll it up.
The problem of course is every time it rains, some water seeps into the ends and the streaks reform, though not moldy or quite as dark.
I can of course re-clean it every time it rains but I have discovered that the awning gives just as much shade with the streaks, as it does without the streaks.
Be safe
DutchmenSport
Normal.
trailer_newbe
In southern Arizon we rarely need to worry about this happening. Our awnings just burn in a few short years, then they are done.
2018 Jayco White Hawk 28RL
IAMICHABOD
Normal thing,capillary action or wicking.It can be somewhat stopped by a cover.
Like the one smokedummy made it will also protect from the sun,it seems to keep mine dry.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
