โFeb-06-2016 04:15 PM
โFeb-12-2016 07:33 AM
CLHEJ wrote:
Thank you BarneyS. Yes, that is the setup I currently have. I do have a bit of work to do prepping my old unit for trade, so I will remove the Dual Cam and put it on my new TT when I take delivery.
Thank you again for the advice.
Craig
โFeb-12-2016 05:46 AM
โFeb-11-2016 10:37 AM
CLHEJ wrote:
One last question regarding the Dual Cam. The one I currently have is approximately 15 years old. I'm getting ready to trade my TT in on a new one. Should I consider upgrading the Dual Cam, or are there really no upgrades to the newer versions?
Sorry for the dumb question, but just curious if there are any major upgrades to newer Dual Cams.
Craig
โFeb-11-2016 04:27 AM
โFeb-08-2016 05:39 PM
โFeb-08-2016 12:54 PM
โFeb-08-2016 12:16 PM
โFeb-08-2016 10:24 AM
โFeb-08-2016 09:30 AM
GrandpaKip wrote:
I have used the Andersen hitch for 2 years on 2 different campers. I really like it for the reasons stated above. However, I would be concerned about using it on anything with a tongue weight above 700 pounds or so. Then I would want some definitive experience from other users at those weights. For smaller and lighter campers, the Andersen is the best choice as far as I am concerned. Easy to use and set up. Neither camper showed any slip problems on the tongue and, so far, no problems with the taper and brake material. Overall, it has worked exactly as advertised.
โFeb-08-2016 09:17 AM
โFeb-07-2016 07:15 PM
โFeb-07-2016 09:09 AM
โFeb-07-2016 08:16 AM
TomG2 wrote:
What makes it a "Downgrade"? Ever used both? I have.
โFeb-07-2016 08:09 AM
DutchmenSport wrote:
My suggestion, keep the dual cam and save your money. Only IF you are having problems with the dual cam, or parts breaking or wearing, THEN consider changing. But to change, just for the sake of changing, ... keep what you've got! Save your money.
