Oct-17-2015 04:23 PM
Oct-18-2015 09:18 PM
Oct-18-2015 08:00 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Oct-18-2015 05:11 PM
bb_94401 wrote:
If you are going to get chains because you travel often in winter, you might as well get ones that work well in all conditions to get you safely in and out. That would be the cross bar reinforced or V-bar chains.
Oct-18-2015 02:25 PM
Reddog1 wrote:
I would get chains simply cause some states require you to have them, needed or not...
Wayne
Oct-18-2015 01:33 PM
Toad: 91 Zuke
Oct-18-2015 01:08 PM
Oct-18-2015 10:14 AM
Oct-18-2015 09:24 AM
Toad: 91 Zuke
Oct-18-2015 09:18 AM
Oct-18-2015 09:15 AM
Toad: 91 Zuke
Oct-18-2015 09:03 AM
Oct-18-2015 08:57 AM
Kayteg1 wrote:I need help here, I am getting old and easily confused. I'm especially not understanding "Chains on only one side of duallies ...". Also, "... on the way back chain restrictions again, so I put the chains on other side ...".
... Chains on only one side of duallies wear out on that single drive, so while camping on other side I had to replace few broken links.
Than on the way back chain restrictions again, so I put the chains on other side and after another 12 miles the chains were no longer useable.
When with chains going over 25 mph gets pretty risky and uncomfortable, with cables 40 mph is fine.
Toad: 91 Zuke
Oct-18-2015 08:39 AM
Oct-18-2015 07:22 AM
Toad: 91 Zuke
