โJan-25-2016 11:08 AM
โJan-27-2016 03:02 PM
HappyCamper44 wrote:
Already in the process of taking the roof off of our 1997 27ft travel trailer, and thought I'd ask if anyone might have any "do's", "don'ts" or modifications other than what I have in my list below.
1-Repair/replace any damaged wood structure
2-going to run new RG6U Quad shield TV cable throughout
3-check/repair a/c duct work
4-add insulation if needed
5-add in switch/wiring for LED light strip outside under awning
6-move radio antenna from roof to exterior side wall
โJan-27-2016 02:43 PM
srd357 wrote:
Add additional wood blockers where the awning bolts to. If you have
rafters, with a jack on the inside, push up to restore the crown. Then clue and screw 5/8 or 3/4 plywood to the rafters so that they will never sag again. Glue and screw 3/8" plywood down for the deck and round off the edges. Do not reuse the factory termination strip that will allow standing water to find it's way into the trailer. Have your new roof over the front and rear caps, on sloping surface, and use 8" Eternbond Tape to hold it down. Standing water is your enemy!!
โJan-27-2016 02:30 PM
beemerphile1 wrote:
Sirius/XM radio antenna? Regular radio antenna? Add vents? Add skylight?
Really want to get crazy, add a skydeck!
โJan-27-2016 02:17 PM
opnspaces wrote:
Check and secure all the wiring connections to the ceiling lights. We've had people on the forum before with a loose ground in the ceiling and no way to get to it.
I always thought I would add a piece of 1/4 inch ply around the AC and all other roof penetrations and under the rubber roof. The thought is to make the penetrations higher than the surrounding roof so that water will run off and can't puddle around the opening creating a leak. I'm not sure though if the rubber would lay down smooth though.
Redo and reseal all marker lights.
Definitely reseal all the duct work. But use the real metal duct tape and not the cloth $1 a roll cheap stuff that we all like to call duct tape. Link
โJan-27-2016 02:04 PM
93Cobra2771 wrote:
Insulation would be my priority. Due to the small amount of area, paying someone to come in and spray foam would be ideal.
The ductwork is horribly insulated as well, so it would be awesome to get it sealed up nicely.
If you've ever considered any LED strip lighting inside, now would be the time to run the wires for it. And definitely run wiring for any outside LED under awning and such.
Might even be a good time to sketch out a wiring diagram of what is in there, just so you will know if needed, in the future.
Did I mention insulation? ๐
โJan-27-2016 01:54 PM
gbopp wrote:
Maybe you can upgrade to a better insulation and install additional or double the 'rafters' to strengthen the roof?
โJan-26-2016 01:03 PM
โJan-26-2016 09:28 AM
โJan-26-2016 08:45 AM
โJan-26-2016 07:06 AM
โJan-26-2016 05:26 AM
โJan-25-2016 12:42 PM
โJan-25-2016 12:29 PM
โJan-25-2016 11:39 AM
