Anybody besides me using old school WD hitch?
Drum
I'm still a forum newbie, and one thing I've noticed is all the talk about the newer WD hitches like Hensley and Equalizer. When I go camping, I guess I don't really pay attention to others' hitches. Before discovering this site, I thought most people used the old school bars with chains and a separate anti sway bar. I can use an old pipe for leverage if needed to set the chain tension. That's what my dad used and it's what I use. It's simple to set up and gets the job done with no issues for me. Am I truly in the minority as it seems by reading the threads here?
Gary in Western NC
29 REPLIES 29
Slowmover
(Deleted)
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
bfever74
I have the bars and chains on my 2000 Terry 24' TT that I tow with a 2010 F150. I generally use them every time, although I don't always use the sway control. My trailer never seems to sway. I also have the integrated trailer brake controller with anti-sway control. Very Neat! If the truck notices excess sway, it activates the trailer brakes to straighten it out. I hope I never get to experience it though!!
2010 Ford F150 FX2
2000 Terry Lite 24' TT
JiminDenver
We have a Husky WDH and a single friction sway bar.
I have felt just a bit of sway as we are passed by the big trucks but wind does nothing and it's always windy here it seems.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
Mvander
Old school (but newer) Curt round bar with friction bar.
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
Macrosill
Old school here.
I have a Husky round bar with the chains and a friction anti-sway device.
Thanks,
Brian
TT = 2018 Wildwood 31KQBTS
TV = 2006 Ford F-350 CC DRW 6.0
Lowsuv
yes.
old time equalizer hitch with the chains .
it could be vintage 1981.
it does , however , have a recent nice matte black spray-can finish .
grandpa-gene had it laying around in his shed and gave it to me when i bought my first travel trailer .
that was 18 years ago .
i started towing boats in 1964 .
don't need no stinkin' equalizer for that .
Passin_Thru
I have a Reese dual cam with chains. I also have an old Reese Strait line but think I'll sell it.
Ron_Gratz
jerem0621 wrote:
---The only difference is that Equal-i-zer uses metal on metal friction while a sway bar uses metal on brake pad material.---
That's true -- as far as the mechanism goes.
However, the Equal-i-zer has potential for creating several times as much sway-resisting torque as a friction "sway bar" can.
Ron
usmc616
dodge guy wrote:
I have the Dual Cam which uses the bars and chains. It just has the sway control built into it!
X2
SEMPER FI
Joe,Joyce 4 kids & 5 dogs
2017 Chevy Silverado, 4x4, 3500HD, LT, Long Bed, Dually, Duramax Diesel, Allison Transmission, Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.:B
69_Avion
I have the old fashioned WDH on my 1988 Avion 34' TT and I don't even have a WDH on my 19' Camper/Trailer with my Avion C-11 on it. I just took it to the Overland Expo in Flagstaff, AZ and in cross winds at 65-75 MPH it did just fine. Old school works for me.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
jerem0621
I love my old fashioned, reliable, wd hitch and dual friction sway control.
You are not unsafe if you don't use one of the different friction sway control devices (which the DC and the Equal-i-zer are) as a matter of fact sway control is not about what brand hitch you have.
Note: I have both Dual Friction bars and DC devices. I prefer the friction bars over DC. Equal-i-zer is about the same. The only difference is that Equal-i-zer uses metal on metal friction while a sway bar uses metal on brake pad material.
NOTE: If your trailer is over 25 ft you need to use TWO friction bars. Many people miss this and go from one and skip the second which would have taken the rest of the wiggle out of the rig and go straight to a DC or something else.
Thanks!
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
plumberdad70
i have an equil-i-zer and the only reason is because the TT had nothing when we got it and i got the WD set up for $175.00 on craigslist!!!!!
1997 Ford E-350 XLT 15 passenger
2000 Rockwood Ultra Lite 2602
Hammerhead
I use the standard spring bar for weight distribution and a single friction bar for sway control. I've towed fairly short trailers and sway hasn't been a problem .
Bonefish
Alignment --In simpler terms the worse pulling trailer I have ever towed was found to have left side axles center to hitch center versus right side axles center to hitch center off by 3/16 of an inch. Does not sound like much but it fought you all the time while towing.
