โDec-28-2014 04:31 PM
โJan-02-2015 05:39 PM
โJan-02-2015 05:15 PM
โJan-02-2015 04:15 PM
v10superduty wrote:
"Hey, you got a 2012 Ford. You are good for at least 10 more years...:W"
I posted the thread to find out if anyone has actually faced the insurance question yet, but apparently no one here has?
โJan-02-2015 03:59 AM
Mike Up wrote:
While I like Ford, I won't buy an aluminum truck. Aluminum is very hard to weld and why many users use rivets instead of welds.
"I agree, its been proven in severe use of boats that a riveted Lund will hold up better than a welded Crestliner. But the best is combination using epoxy, which I believe is what Ford is using. One of the followers have said they will use "weld" construction when they switch to aluminum in a few years "
Aluminum corrodes just as bad as steel rusting, so both need to be sealed/painted.
"Can't agree that aluminum corrodes as bad as steel, especially if raw. If sealed, aluminum wins here."
Aluminum will have dissimilar metal corrosion when bolted to steel. Ford used fasteners to stop this but I have a wait and see attitude, on how well these will work after being exposed to snow and salt. Aluminum does not like salt, causes pitting and chalking.
"Aluminum likes salt better than steel"
Aluminum is lighter so the F150 will get better mileage. Hum, perhaps at even higher costs of repairs due to corrosion. I'll pass and let the guinea pigs try first. ๐
โJan-02-2015 03:51 AM
โJan-01-2015 05:45 PM
v10superduty wrote:
magicmantx
New Member
View Profile
Offline
Posted: 12/31/14 11:48am Link | Quote | Print | Notify Moderator
There are a lot of benefits to the lighter aluminum . That said if it does get damaged good luck in finding a competent shop to make repairs. Expect much higher repair costs and subsequently higher insurance rates. while aluminum panels can be repaired its much more difficult and time consuming and the vast majority of body men struggle with it usually opting to replace rather than repair.
Its posts like this one above why I started this thread.
In my opinion this post is full of misinformation and inaccuracies.
โJan-01-2015 03:48 PM
โDec-29-2014 02:55 AM
womps wrote:
Talk to your insurance company too find out the difference. Every insurance company will be different.
โDec-28-2014 05:24 PM
