โAug-04-2015 02:16 PM
โAug-05-2015 04:45 AM
gmckenzie wrote:mooky stinks wrote:
I just weighed my 2015 6.2 LTZ 4x4 Max Tow w/ Outback 277RL on the way to the CG packed for 4 days with DW and dog and a full tank of fuel. In other words the absolute heaviest that MY rig will ever be. Numbers are:
Steer axle 3460 FAWR 3995
Drive axle 3920 RAWR 4300
Total TVW 7380 GVWR 7600
Trailer axles 7400
As you can see, I was under every rating but close to my GVWR. (220 lbs.)
I tow approx. 1000 miles/year so a 3/4ton truck just doesn't make sense for me. I know because I did it for 2 years. The 6.2 MAY require better fuel when actually towing (which I use) but it runs fine on mid-grade the other 14000 miles/year that I drive. It also tows nicely on the NYS Thru-way at 65mph at 1700 rpm's.
Do you know what your toungue weight is?
โAug-05-2015 04:42 AM
โAug-04-2015 09:28 PM
gmckenzie wrote:campigloo wrote:
Why not just get a 3/4 ton with a gas engine? Problem solved.
$10K - $15K more money.
โAug-04-2015 09:13 PM
โAug-04-2015 08:56 PM
Trailer axles 7400
โAug-04-2015 08:55 PM
Try harder. A HD truck doesn't cost much more. I paid $39k for the truck in my sig, and could do a bit better right now. A 6.4 would've run in the $33k range with the same options and configuration.
โAug-04-2015 07:14 PM
โAug-04-2015 07:13 PM
โAug-04-2015 07:04 PM
โAug-04-2015 06:45 PM
โAug-04-2015 06:42 PM
When you compare the MSRP on the window stickers and factor in the 2 option differences, the price difference between the 2 trucks was well under $3,000.
You pay about $500 more for the GMC name over the Chevrolet name. With that in mind, the real price difference between the 2 trucks was less than $2,500.
My price comparison was between loaded out SLT / LTZ 4WD Crew Cabs. It is possible the price differences could be larger on lower trim levels and/or cab configurations.
I tried to locate Chevy or GMC 1500 with Max Tow Pkg, but they were nearly impossible to find.
โAug-04-2015 06:35 PM
โAug-04-2015 06:12 PM
โAug-04-2015 05:43 PM
jwc99 wrote:Not any more. They did for the first couple model years, but have since dropped the recommendation for premium fuel.
If you go with the 6.2 I think they recommend premium fuel. I have read where some are running mid grade. I didn't want the extra fuel cost of premium since the truck is a daily driver. Another note on my 5.3, it now takes 8.5 quarts of oil for a change. I have heard several people complain about the cost of changing the oil in a diesel, well it looks like I'll be getting close to their cost with synthetic oil. But if I can't afford the cost of an oil change I probably don't need to go camping anyway.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
