Anyone seen or used one of these
Tequila
http://www.axlecrutch.com/
Looks like it might be a handy item to have in a pinch. I wonder if you could make one yourself, it looks pretty simple.
15 REPLIES 15
Jerry9n
Would work for a broken spring, but when I broke one the two truck guy just put a wood block over the axle and used ratchets to hold it in place. Wouldn't have thought of it but easier than carrying another piece of hardware. Easiest part was calling the road service and let them take care of it and pay for the towing.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
Huntindog
This is not fix for a flat tire as some seem to think.
A broken spring, or in my case a spun bearing.
I used a rachet strap. No worries about overloading ST tires as I run LTs.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
Community Alumni
Not applicable
This is the same idea the Class 8 guys have used for decades. When you're out in the middle of nowhere and blow two tires on the same axle or a brake locks up, you chain up and limp to help. Ratchet straps work just as well for travel trailers.
Ron3rd
Nice idea. Would have come in handy when we broke a leaf spring on our old trailer. That will stop you in your tracks quick!!! Had to put the trailer on a flatbed.
Equilizer Hitch
Honda EU2000
RCMAN46
bob213 wrote:
Been a boater for 40 years and always carried enough chain to tie up an axle in an emergency. Most older boat trailers didn't have spare tires or it just didn't look "cool". That would have been an easier solution. Todays trailer have such a variety of suspension not all would benefit, but in an emergency situation I would use it.
Were your boat tires loaded to 90% of the sidewall rating.
My boat was not but my 5th wheel original tires were.
In fact the trailer had a GVW of 12,000 lbs with 5,000 lb axles.
So with 2500 on the pin the axles would be at the max.
Beachums
The last time I used a scale, I was up to about 90% of my rated load of all 4 tires. So there are several reasons why I would not fill my finite trailer space with one of these tools.
As stated before, 90% of my total tire allotment would mean obviously I would be grossly overloading a tire on one side of the trailer. With so many variables of why you would lose a tire on the road, one pattern always seems to emerge..... whatever condition one tire is on one side of the trailer, the other is usually similar. In other words, chances are the other tire will likely be close to failure as well. As such, I would not want to rely on that one tire to drive 50' let alone the probable miles needed to find a repair facility.
Pound for pound, dollar for dollar I would carry around a second spare before investing in one of those.
All that being said, I don't typically yank my trailer on very long trips. So I am sure my opinion doesn't apply as much as the full timers out there.
2004 Ford Expedition 4X4 3.73 w/quick shift kit
Reese DC Straight Line/ Prodigy P2 Controller
2010 Coleman CT 250 GS
MUDDYNOLL
That would be a great help in the instance of a broken main spring to help get you off the highway. It's a great idea but IMHO not very practical to carry around with you all of the time as a broken spring is less common than a flat tire.I also carry extra lug nuts lust in case. They dont take up much space.
majorgator
Why spend money on that when a few good cheap ratchet straps will work just fine? Easier to carry ratchet straps and/or chains than that big clunky thing. Temporary means just that...ropes, tie-wire, 100 zip ties, or whatever it takes to get you to the repair shop.
SAVED BY GRACE, THROUGH FAITH*
1998 Coachmen Catalina Lite 248TB
TV: 1996 F350 Crew Cab 4x4 7.3L Diesel (a man's truck)
*signature amended so that religious components aren't included (per "Admin")...hooray, now nobody will be offended by my personal beliefs
NashTT
Traveled with a friend back in the late 70's who lost a wheel on I70 in OH. I was behind him and watched the lug nuts come off before the wheel--no amount of horn honking or light flashing got his attention I couldn't pull along side because of traffic and the TT I was towing. We ended up chaining up the rear axel with a tow chain on one side and limping to an exit. This was before radial trailer tires were common and it seems blow outs were less frequent but his tire held up fine for the short haul. We ended up spending the night under an overpass and got repaired the next morning. His trailer was a seventy something Holiday Rambler and I've got to believe that it was heavy. I believe this type of arrangement would work in most cases for a short distance at a reduced speed although it should probably be a backup used only after the spare. In my friend's case he'd lost his lug nuts so the spare was useless.
"The opposite of Progress is Congress"
2013 Nash 23F
2008 Doge Big Horn Hemi Quad Cab 3.92
Reese 1000 bars-Prodigy Brake control
Jill, the crazy Rat Terrier always along
bob213
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
mooky_stinks
It does say it's for TEMPORARY support to get to a repair place. I'd much rather be able to use something like this to get to an exit or service area than be stuck on the shoulder of an interstae.
"The AxleCrutch is a temporary support device for multiple axle trailers with leaf spring suspensions. The AxleCrutch is easy to install and permits you to drive to a repair facility on your own.The AxleCrutch provides temporary towing capabilities to a trailer that would otherwise be immobile due to axle, suspension, tire failure including: bearings, hubs, leafspring, u-bolt, lug nuts, spindle, and wheel"
2020 F150 XL Screw 4x4 6.5โ€box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
tvman44
That would be a awful lot of weight to put on a single tire especially when they are already loaded to just about their max, then to double that. Probably would not get far with a TT or 5er. ๐Ÿ˜ž
Papa Bob
Husky 16K hitch, Tekonsha P3,
wmoses
nomad297 wrote:
It would need to be a pretty severe pinch for me to resort to using that. The last thing I want to do is overload an ST tire.
Bruce
X2. Well said.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
Tequila
I was thinking about being stranded somewhere. You could probably limp to help or get to to a safe place to park it until help arrived.
