Arctic Fox 990
mtaviator
We found a good deal on a used 2004 Arctic Fox. So now for a truck. The dry weight of the camper is 3400. We are looking at the Chevy Silverado 3500 dually. I want to make sure it is very stable feeling. I had a TT sway on me once & that's not an experience I care to repeat. Any suggestions or comments on the truck.
Thanks!
Mtaviators wife
11 REPLIES 11
cubbear
I have 990 on f350 dually upper and lower stableloads works great loaded I am at 14,400 Lbs
mtaviator
A lot of really great information. Thank You everyone! I'm feeling better about driving it. And I am pretty sure we will be putting the stable loads on. Everyone seems to highly recommend them. Can't wait to head out with the family for some quality time. I'd love to someday spend 6 months to a year out on the road.
Fisher_Bill
I have a 2006 3500 Dually with the 6.6 Duramax and the Allison Transmission and never looked back, this truck came with air bags and I had stable loads from last truck (in sig).
My stable loads go between the bottom over load leaf spring and the rest of the pack, stops side to side sway but more importantly to me it stops the porpoising from front to back.
My truck weighs 8900#'s empty, about 14,000 plus with the 1150 loaded and I can pull a 21' Thunder jet in addition to the Arctic Fox.
Bill
2006 Chevy 3500 Dually 6.6 Duramax Diesel & Allison Transmission
2010 Northshore 28RK by Dutchmen
Our first fifth wheel!!!
scud
I haul my 990 with a SRW F350. It's heavy. However my truck handles it well. I don't fill my 60 gallon fresh water tank which would add 500 pounds of weight.
1999 F350 4x4, crew cab, diesel, SRW, front and rear Hellwig sway bar, Hellwig air bags, Tork lift fast guns, super hitch and truss. Toyo AT 2.
2016 Arctic Fox 990
gbsb
I have a 2008 990 on a F450 Ford Flatbed works great for us. We did install stale loads and it made a world of difference. I weighed my 990 a couple of years ago while in Oregon, It was 5000 ponds but we were full of water, propane, clothes and every thing else.
towpro
Check how the clearance lights on this rig have been sealed. I have read several posts with older arctic fox units where clearance lights leaked which lead to delamanation.
Look whole camper over well for condition of caulking and any signs of water leaks which can cause delamanation. Even if it was stored inside, bad caulking can quickly cause you problems once you take it outside.
water leaks on front clearance lights can cause damage all the way down to under overhang.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
deltabravo
What year GM 3500HD dually are you looking at?
2011 or newer is my recommendation. in 2011 the GVWR was increased.
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
wcjeep
Torklift Stableloads. If you think you need airbags try Stableloads first. Great tech. I also have Torklift stairs and handle/rail for my Arctic Fox.
Grit_dog
Navigator
Navigator
As said, plan on that camper being around 4500lbs ready to camp.
Any newer dually will be well suited to haul it with ease. Still going to need some rear suspension help on a 3500 though.
jimh406
The truck should be fine.
I'll tell you that my DW didn't enjoy pulling a TT with the Expedition that we had at the time. She regularly drives our truck with truck camper. I think you'll like it.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
CAJW
Depending on the year of your dually, you should be fine. Check your rated payload and figure about 4200-4500 lbs for a fully loaded AF990. Someone who has a 2004 will hopefully chime in if they built them lighter then vs now. Our 2013 Chevy carries the heavier AF 996 just fine with minimal upgrades. See my signature for suspension mods and good choice as Northwood builds a quality unit.
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
