Arctic fox truck camper 990 or 992?
cathtea
We are considering buying a 2016 992 vs a 2017 990 TC. I have been over the floor plans, weight and other specs. Still indecisive. it is for true 4 season camping in Yukon and Alaska with 2 adults and 2 kids. Planning to have it for 10 years. Anyone have experience with either of these TCs they would like to share?
Also considering a 2015 Ram 3500 Laramie dually. Overall its a big rig for us, but I think it will take us places that we want to go ๐Ÿ™‚
49 REPLIES 49
GeoBoy
cathtea wrote:
Gear ratio? Does 410!make a differ ce or too high revs on the highway?
Are you looking at a gas or diesel? Gas I would go with 4.10's, diesel 3.73's.
towpro
I run 410's in my 2015 Diesel with the Aisin trans. I could run lower, but that is what it came with. But when that light turns green, if I want I can "run with traffic" :).
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
cathtea
GeoBoy
Troutguy wrote:
macdale4 wrote:
I bought a brand new one in 2014 and had nothing but problems with it. My recommendation is don't buy one.
This thread is about AF 990s and 992s! You had an 1140! When are you going to quit whining about your so called bad experience? I guess some guys just like to complain about everything.......
Why can't you stay on subject?
X2. If someone has a question about a Lance, then participate. You probably wouldn't be happy with a newer Lance either.
Bedlam
Moderator
Moderator
My slightly smaller AF811 was reliable and handled temperatures from the single to triple digits. Having a curb side slide is more convenient than street side. If you are trying to stay thin, you can open the slide just a touch if you need access to something - There is no reason you have to fully open the slide if you do not need to.
With the number of people in your family you may want a larger camper for some elbow room.
Troutguy
2018
RAM 3500 Crew Cab 4x4 DRW
Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWR
2018 Arctic Fox 1140 Truck Camper &
Honda EU2000
macdale4
Dale & Eileen
1998 Lance 945 Legend
2011 Ford F-350, dually, 4 X 4
towpro
we first had a wolf creek 840 which has the restricted entrance into the bunk area. on some real hot nights (even with AC on) we found we needed a small fan to circulate air or it got hot in the bunk area.
we we went with the 990 which is wide open between bunk and cabin area for air flow. seems to have solved the problem.
2022 Ford F150
cubbear
in the winter I camp where we have a electrical connection or I run generator with extened run fuel tank as we are gone all day snowmobiling. I then plug in electric heater to keep camper warm. I have storm windows but if I did it again I would get thermo pane windows. I put reflex on some windows and under the bed put switch on fan that blows warm air to tanks been out in -30 degree weather
fpoole
cathtea wrote:
Thank you all this is super helpful!!! We are currently looking at a couple of Dodge Ram trucks 3500 dually with or without air ride aka air stabilization system. Anyone have experience w air ride versus after market air bags re: stability, diving performance and maintenance, particularly in northern climates and also towing?
Also, all those who responded have 99s, any 992s out here????
So great to hear about winter performance. This would be so awesome as we live near some gorgeous mountain passes!!!!
Thanks again!
Temps... in a 990
Well, my personal best, heheh, is 14F and no problems.
but that's probably like Summer to you all up there so can't say "How Low, shall we Go..." Hit 16f a few weeks/month ago, no big deal but as noted, blowing through Propane. I have the 2 7-gal bottles and a back up 7-gal used for BBQ and a backup in worst case scenarios, I turn on the water heater to keep that warm and I've heard of opening all the cupboards to allow heat in, but haven't gotten that far yet...
So far, no big deal with Truck or Camper.. sigh, that I KNOW of at least... I also have Solar, which doesn't help if covered in snow, so carry a Honda and have the OEM Onan propane as a backup to the backup.. heheh,
Like the old saying " One is None, Two is One"...
Hope that helps...
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10โ€™ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nโ€™ Go, E-Bike
RS1 Buggy
frank
Pooles website
bighatnohorse
My preference is for the slide to open toward the Curb. (The 990)
I prefer that for side-of-road stops or stream side stops for the view.
The down side is that the road crown slopes in the same direction which makes longer term parking not so good with the slide open.
The 992 slide opening is over the elect/water/sewer hookups in parks. That leaves room for camp chairs etc on the passenger side - so that's a plus for the 992.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
Grit_dog
Navigator
Navigator
No comment on 990 vs 992. That's just personal preference imo.
You ar picking a very capable sweet combination though!
Regarding 4 season camping, there's a difference between "normal" winter and the northern reaches of the continent. Just because Arctic is in the name does not mean it's Arctic rated! I'd expect to do some mods/ better insulating/and prep for "true" 4 season up north. They are more of a 2.8 season camper up there without some help. Been As cold as low teens/single digit nights and above freezing and sunny during the day and a AF 860 with no additional help/insulation peeled through over a 30lb bottle of propane and would run the batteries dead on the furnace fan before you were ready to get up in the morning.
Any colder or more use at those temps would have warranted shoring up some things on the camper.
On the truck, again talking out my _____but I would prefer simplicity in extreme low temps. At 30-50 below lots of things break that shouldn't.
cathtea
Thanks again!
cubbear
Wife and I love our 2014 990 we have a 2015 ford PSD CC LB with upper and lower stable loads. Handles great always loaded to the max water propane fuel, ect. As we live in northern Mn we use in winter just like summer. we take it snowmobiling full of water and everything. on the road with generator, clothes food ect we weight #14340 Front #5640 Rear #8700
maxum1989
Here is a review on Truck camper mag that may help you out.
http://www.truckcampermagazine.com/camper-reviews/2017-arctic-fox-992-review/
2008 Chevy 2500hd Duramax/Allison
2006 Wildcat 27 bhwb
2009 Lance 830 *Sold*
2011 Northern Lite 8.5 *Sold*
