Atwood Jack Switch Light Won't Stay Lit
omiles
Hey all,
Anyone ever had this problem? The light on the Atwood jack switch near the floor in my Lance Camper won't stay lit. I am hooked up to full power. I have replaced the switch, the problem is still there. Any help would be greatly appreciated!
4 REPLIES 4
ScottG
So are you saying the switch is still in the "on" position but the light is off?
cyntdon2010
loose ground connection on the switch or other end.
X2 bud has the right answer
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jimh406
I believe I've had the issue with low batteries. Believe it or not, the other fix is WD-40 or similar sprayed in the switch. I'm not sure why replacing the switch wouldn't have worked.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
