Atwood Water Heater 6GA-8E
Workingclass
I am getting to much flame around the adjustable gas tube and is melting the wires. I have adjusted both ways and it still occurs. Can someone give me an idea of whats going on. I am worried something will catch fire but I don't want to have to constantly monitor it. Thank you
7 REPLIES 7
hohenwald48
Clean out the burner tube.
It could be the regulator but that's highly unlikely. Especially if all your other appliances are working normally.
This is the time of year that spiders and wasps are building their new summer homes.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
Old-Biscuit
Hondavalk wrote:
BluegrassBill wrote:
Pull the tube and run small brush or wire through to clean out spider web and you're good to go.
X2
This ^^^^^
AND run a wire thru combustion chamber out thru exhaust then tie rag to wire and pull it back thru to clean the 'U' tube out
AND with burner tube off.unscrew the main gas orifice (brass insert where burner tube attaches to gas valve)
Soak it in alcohol and then blow it out....NO poking things thru the orifice No/No
Workingclass
the regulator at my tank?
Thanks for the replies I will check the regulator and clean with a wire brush.
Hondavalk
X2
BluegrassBill
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
newman_fulltime
sounds like you have a bad regulator
Workingclass
Sorry its an Atwood water heater 6GA-8E that im referring to.
