Jul-23-2017 02:28 PM
Jul-25-2017 11:13 AM
Hemling wrote:
This is the only major complaint I have (2017 Keystone Sprinter 33bh) is that the awning is so close to the sharp corners of the slide out.
Jul-24-2017 12:30 PM
Jul-24-2017 06:58 AM
Jul-24-2017 05:23 AM
Jul-24-2017 04:54 AM
Jul-23-2017 09:03 PM
Jul-23-2017 08:01 PM
Jul-23-2017 07:59 PM
MitchF150 wrote:
Well, if you tilt it too much, it can form a pool and if it rains more than it drains from the tilt and fills your pool.. Guess what happens??
Know that from experience..
Tilted my awning during a mild rain storm (first or second time out with the trailer back in 2002).. Tilt was too much to allow to drain off the end faster than it was raining.. Ended up pooling in the middle of the awning..
Luckily, I discovered it before it did any damage. Was able to drain the pool and looked at what happened and set the tilt about 'half' as much..
Rained just as much for the rest of the night and no pooling at all...
Worked for me. Been setting my awning at just a slight tilt from then on and have gone thru thunder storms and have never pooled my awning since then.
On edit, the only other way I have set my awning and not had it pool, was so keep both arms attached to the trailer and at it's lowest setting.. You can't open the door more than half way, but that also keeps the water from pooling..
Mitch
Jul-23-2017 07:07 PM
Jul-23-2017 04:11 PM
Jul-23-2017 04:08 PM
Jul-23-2017 03:27 PM
Jul-23-2017 03:20 PM
MitchF150 wrote:
But, don't tilt to too much.. That's just as bad!
Mitch
Jul-23-2017 02:57 PM
