Feb-25-2022 06:10 AM
Aug-24-2022 07:36 AM
JIMNLIN wrote:Trailer: 2011 Keystone 25RS
GVWR: 7500#
Axles, bearings, brakes, etc. have never been serviced. (the way I purchased from original owner)
Mileage: Approx. 10,000
My thoughts on trailer brakes or bearings have never been serviced in 11 years/10k miles.
I've put over a dozen new non rv trailers in service using 3500k up to 11k axles...the same sizes and brand axles used on rv trailers.
Before any new or used trailer was put in service the hubs were pulled all brakes and bearings were R&R and serviced.
Several times we caught a axle with no grease on one end or simply not enough grease for that type of work. Or a brake magnet with no 12v due to various reasons.
Point is don't assume the bearings have grease or even proper amount of grease or the brakes are working just cause the trailer is new or used with just 10k miles.
Comparing trailer bearings/wheels/suspensions/etc vs our truck/car/van/suv same components IMO is apples vs marshmallows.
Aug-24-2022 06:58 AM
Aug-24-2022 06:50 AM
GVWR: 7500#
Aug-24-2022 03:26 AM
klutchdust wrote:
Replacing the bearing, replace the race. Pull a wheel, replace the seal. Always use a torque wrench on the lug nuts.
Aug-22-2022 07:17 PM
Aug-21-2022 09:15 AM
Aug-20-2022 04:14 PM
Feb-28-2022 06:52 AM
Feb-28-2022 05:13 AM
Feb-27-2022 04:24 AM
CharlesinGA wrote:
Race drivers are cheap and readily available. I used a punch and care for many years, till I bought a race driver set. Night and day difference. Can drive the race in a couple of good hits and move on to the next one, and no worries about anything slipping and damaging the race or your fingers.
I gave up doing things the hard way.
Since most auto parts stores have them in the loan pool, why fight it?
For seals I use a wood block and hammer to get it started and then off to the arbor press with a socket that sits just right on the seal.JRscooby wrote:
The only "special" tool I grab is a punch, long enough to reach thru hub, leave room to hold. Needs a flat point, to catch the edge of race. And works better if it is something hard, tool steel, so it will transfer the impact to race, not distort or bounce around. Mine is long enough that I can catch the seal thru bearing, and pop it out.
Though I do not own any, Snap On actually makes punches specifically for bearing race removal that are oval tipped. Not cheap but if you do a lot of bearing races, its probably worth having. I miss the older auto hubs with notches cast into them behind the races to give you full access to the back side of the race,
Feb-26-2022 06:55 PM
Feb-26-2022 04:42 PM
Feb-26-2022 03:28 PM
JBarca wrote:
Oh and another thing, when buying the grease seals, look for the double lip seal with the garter spring inside. They do sell single lip seals in the trailer industry with no garter spring. Yes they work, but they are so cheap it is pathetic to consider using them on such an important thing to keep dirt out of the bearings. The cost to upgrade to the double lip seal is not much and very much worth it.
Feb-26-2022 09:07 AM
Feb-26-2022 08:54 AM
Baja Man wrote:
Are there any good step by step procedures or videos you can refer me to?
Are brake drums turned?
When are brake shoes replaced?
Are magnets replaced? How do you inspect and what to look for in terms of wear, required thickness, etc?
