Feb-26-2020 11:24 PM
Feb-28-2020 08:23 PM
Feb-28-2020 07:50 PM
ktmrfs wrote:valhalla360 wrote:ktmrfs wrote:
carefull, it may have a 3500lb axle but still could have a lower axle weight rating driven by the tire capacity. Rating will be the lower of either the axle or tire capacity.
Doubt it as that would be a lawsuit waiting to happen.
not as long as trailer sticker shows the correct allowed weight. If the axle is 3500lbs rating and the tires are 2800lbs and the sticker says 2800 it's legit and correct.
Look at most trucks and it's often the case that the rear axle rating is higher than the tire rating and the sticker allowed weight is lower than the axle is capable of.
Feb-28-2020 09:18 AM
Feb-28-2020 08:46 AM
Feb-28-2020 05:28 AM
valhalla360 wrote:kellem wrote:
The axle is likely a Dexter and will be labeled with the info.
Yes it's very common in the RV world to have the trailers GVWR to exceed the axles rating, surprisingly.
My last 2 trailers had (2) 3500lb axles yet both trailers exceeded 7000lbs in GVWR and in scale weight without issues.
Where does the GVWR sit with the hitch weight added in?
On an 8000lb GVWR trailer, you are likely looking at a 1000lb hitch weight, so add in a pair of 3500lb axles and you should be fine.
But in this case, the OP just mixed up the dry weight with the axle rating.
Feb-28-2020 04:40 AM
Feb-28-2020 04:38 AM
Feb-27-2020 03:04 PM
Feb-27-2020 02:49 PM
Lwiddis wrote:
Fooling with numbers to make a single axle trailer seem safe, adequate for your needs.
Add water, batteries, propane and your stuff you’ll be over max TT weight.
Feb-27-2020 01:08 PM
Feb-27-2020 10:51 AM
ScottG wrote:
Simply, you're missing the weight that is on the tongue.
Feb-27-2020 08:31 AM
valhalla360 wrote:
You are mixing up different numbers. I checked Lances website:
Ratings:
GVWR = 3700
GAWR = Not Listed on their website but probably 3500lb as they won't make a custom axle for a travel trailer. You get the GVWR when you add the hitch weight.
Empty Weights as it comes from the dealer:
Unloaded Axle Weight = 2530
Unloaded Hitch Weight = 245
Unloaded Total Weight = 2775 (2530+245)
So you have 925lb of cargo capacity before hitting the GVWR
Of course this is all per the design calculations, so it might be off by a bit in real life.
Feb-27-2020 07:08 AM
Feb-27-2020 07:05 AM
