back up camera
jefffoxsr
2015 Ford F150. I bought a back up camera.
What is the best way to run the wire bundle inside the truck?
There is a grommet where the hood release cable goes through the firewall but it is super tight and I don't want to wreck it trying modify the grommet in that area.
I could run the wire up from underneath the truck into the cabin at the drivers side a pillar area. It would run up and over the weatherstripping. With that method I worry about getting noise or water in the cabin.
What are my other options for neatly and efficiently bringing the wire bundle into the cabin?
Thanks.
Jeff Fox
3 REPLIES 3
bbaker2001
I ran my wires all the to engine area. found a grommet I firewall and ran it there. tucked it neatly behind carpet
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
bgum
There should be a grommet between the bed and cab.
Nicholsfamily05
I wouldn't use the weather stripping idea. As I did that on our 2006 mega can and found it leaking.
What I did recently was I removed the flooring and found a spot where I could drill through at an angle and add a grommet there to keep the moisture down and out. Haven't had any issues with it and since the wire lays flat no marks in the carpet. I seal around the outside just incase.
Last two trucks have done this and no issues.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
