Apr-27-2013 04:55 PM
Apr-30-2013 06:17 AM
Camper_Jeff_&_Kelli wrote:
Odyssey and Lifeline promote differing recommendations on how best to maintain their batteries. The Boondocker power supply appears to adhere more to the Lifeline standard
Jeff
Apr-29-2013 10:35 PM
Apr-28-2013 12:52 PM
Apr-28-2013 11:20 AM
Apr-27-2013 11:28 PM
msiminoff wrote:
Hi Jeff,
It's awesome that Sears was happy to replace the batteries for you under warranty. I often recommend the DieHard Platinums for exactly that reason (plus the nationwide availability).
However those EnerSys batteries are very hard to kill (I have been abusing mine for a long time!)... and based on the description you provided I suspect that root cause of the issue is related to the charging, and not the batteries themselves. In other words; I think that the batteries were simply discharged, not defective. For starters, your charger (and solar panel/controller) are small considering your 200Ah of AGM's. At the voltage you stated (13.2) the batteries would never have reached 100% SOC. They should have been absorption charged at 14.7V and should have been float charged at 13.6. In addition if they had been fully charged and then disconnected when you parked the TC for the winter those AGM's would have a storage life of more than 2 years.
The test that Sears conducted is so far outside of EnerSys's charge & testing protocol that it's laughable... and a 4 minute charge (regardless of current) is followed by a high current discharge is meaningless.
EnerSys has specific guidelines for charging deeply discharged batteries and states that a group 31 battery should be charged at 5A for 24 hours and the voltage should be allowed to rise to as much as 18.0V (the Boondocker can't do that)... then the batteries should have been removed from the charger for 18 hours before capacity testing.
Anyway, now that you have fresh batteries I suggest that you download the TECHNICAL MANUAL from EnerSys and review the information in the charging section. If you are hoping to get many years of service and high capacity from the Platinums, you may also want to consider a larger and more configurable battery charger and solar controller.
Cheers,
-Mark
Apr-27-2013 10:44 PM
Apr-27-2013 09:18 PM
Artum Snowbird wrote:
You guys have been on here for years so no way you let them be connected for over the winter in parasitic discharge...??? Right?
I pull mine off and leave them on the charge they have when I leave them into the dark indoor storage they like.... they seem to work in the days later...
mike
Apr-27-2013 07:15 PM
kerry4951 wrote:
I'd be a little concerned with the reason why they BOTH failed. The two of them both going down seems a little strange. I guess there could of been a bad batch of batteries but just seems highly unlikey that both would fail unless there is another problem causing it.
Apr-27-2013 06:49 PM
Apr-27-2013 06:44 PM
Apr-27-2013 06:35 PM
Apr-27-2013 05:02 PM
