Battery in key fob ?
wanderingbob
Came out of restaurant today , punched the door fob , battery in fob was dead . I could have unlocked with key but next door was Auto Zone , replaced battery , all fine ! My question is if fob battery was 100 % dead would my 2014 Ram 2500 CTD have started , does the fob have to have juice for motor to run ?
38 REPLIES 38
wanderingbob
Thanks for your replies , I hope I never have to find out !
naturist
Can’t say about your truck, but the keyless entry system on my BMW X5 works with a dead fib battery. Both the door lock and the ignition use near field chips, so if the car senses the key within 5 feet of the door, it will unlock when you touch the handle, and as long as the key is inside the car, the engine will start and run. Of course, the fob buttons require the battery to work.
Learjet
I pretty sure the owners manual has the procedure for a dead fob battery.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
ScottG
Me Again wrote:
mich800 wrote:
If it is push button start you push the button with the key fob and it will start like normal.
Are you saying the truck will sense the presence of the fob even if it's battery is dead? Will keyless entry work with a dead fob battery?
Yes, it will start because it uses RFIF technology.
No it wont remotely open the doors because it needs the battery for that function.
stickdog
I can open my F350 without the key or the fob just push the combo to the pad.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Me_Again
Johno02
Don't need the fob, just a key and a good battery IN THE TRUCK!
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
mich800
Margo_S
Yes, it would still run. Does not need fob for engine to run.
Bill and Margo
Traveling Around
2019 Silverado 2500 pulling a 2019 Crusader Lite 29RSLE
