โNov-03-2020 12:20 PM
โDec-07-2020 08:36 AM
โDec-06-2020 03:28 PM
โNov-08-2020 06:10 AM
โNov-08-2020 05:37 AM
jornvango wrote:
2013 Chevy Tahoe with 120K miles. Battery was last replaced Jan '17.
For the past 8 months, especially after a cold night or when we haven't driven the car for a day or two, the car shows low battery level indicator and has trouble starting (but hasn't left us stranded ... yet).
A few months ago my wife left an interior light on which drained the battery enough so the car didn't start. We charged it by hooking up our solar panel to recharge it.
A few days ago after a very cold night (10 F), the battery was so low (as indicated by the gage on the dash) that it barely started.
Yesterday morning, after overnight temps around 35 F, again the battery level gage showed low and the car barely started.
We have been to Autozone / O'Reilly's multiple times and every time the battery, alternator and starter tested 'good'.
This morning I plugged a volt meter into the car. It again had trouble starting. Here are the readouts:
1. Before car start in the morning 12.0 V
2. During start 10.8 V
3. Started the car and during driving 14.7V
4. Stopped the car after driving 30 mins 12.5V
5. After 1 hour of not running 12.2 V
Any idea what is going on? It reallyfeels like one of these mornings the car is not going to start which will be a problem if we're camping off grid.
Thanks!
โNov-07-2020 08:09 AM
blofgren wrote:Grit dog wrote:jornvango wrote:Krusty wrote:
You should get a battery charger and charge the battery up fully. Also, if the battery and charging system test good, perhaps there is something drawing the battery down overnight.
We ended up driving a few hours today. Upon arrival at our campsite, the battery showed 12.2 and a few seconds later 12.0
Is there any way to test if there is a draw on the battery while the car is turned off?
This tells ya it's the battery. Even with a parasitic draw, the battery would be fully charged after a 3 hour drive. And if the alternator wasn't working, you wouldn't have made it to your destination.
Reminds me of your alternator story with your Tahoe! :B
โNov-07-2020 05:51 AM
โNov-06-2020 05:19 PM
Question- did they remove the battery and do a full load test? Just checking the static voltage in the car right after driving it only tells you that the battery has a surface charge and that the alternator works. A specific gravity test (hydrometer) was suggested but that's a little tough (impossible) to do on a sealed battery. I'm with the others, the battery is almost four years old and is toast.
โNov-06-2020 05:11 PM
โNov-04-2020 08:08 AM
โNov-04-2020 06:56 AM
โNov-04-2020 05:26 AM
โNov-04-2020 04:54 AM
โNov-04-2020 04:02 AM
โNov-04-2020 12:43 AM
w2dart wrote:
Do a Battery Load Test
