โFeb-25-2013 05:30 PM
โAug-15-2013 08:36 AM
โAug-12-2013 09:29 PM
โAug-12-2013 08:25 PM
โAug-12-2013 06:32 AM
path1 wrote:
We had a trailer like the pic in advertisment. I really can't say if it helped with lifting but helped holding bed up when you dig something out.
โAug-10-2013 07:59 PM
martipr wrote:
My trailer came with the lift kit standard but the gas springs were way too strong. The bed would lift with one finger but you almost had to climb up and sit on the bed to close it. They put so much pressure on the lower attach brackets that the bed frame on one side broke. I did a repair job and replaced the springs with ones half as strong.
โMar-03-2013 10:12 PM
โFeb-28-2013 10:53 AM
โFeb-28-2013 10:34 AM
โFeb-27-2013 08:39 PM
beemerphile1 wrote:
Make sure you mount those somewhere really solid. You may need to add more wood to the mounting location because the screws will rip out of thin wood.
โFeb-27-2013 04:02 AM
โFeb-26-2013 05:52 PM
martipr wrote:
My trailer came with the lift kit standard but the gas springs were way too strong. The bed would lift with one finger but you almost had to climb up and sit on the bed to close it. They put so much pressure on the lower attach brackets that the bed frame on one side broke. I did a repair job and replaced the springs with ones half as strong. I googled "automotive gas springs" and found more information and suppliers than I could read. One thing I found is that when you don't have to pay for the"RV" name things are much cheaper.
โFeb-26-2013 03:57 PM
โFeb-25-2013 06:02 PM
โFeb-25-2013 05:57 PM
