bent camper leg bracket
bluhaven
I bent the bracket that holds the rear leg, what i'm trying to figure out is do i just unbolt it then bolt it back together or is there an adhesive that is put on. I was stuck on a freeway in so.ca. and in order to get out i had to maneuver between an abandoned vehicle and the guard rail, the leg just barely caught the guard rail and just bent the bracket.
Kevin
96 DRW Dodge cummins,Auto,4:10LSD,05GTO,250 Sea Ray,2004 Arctic Fox 990DB,Torklift tie downs,Super-Hitch,air bags,Rancho 9000's, Power Vision Mirrors.Hockey player for life,Lifetime NRA member,Teamster member for 31 years and retired as of 8-1-04.
4 REPLIES 4
Gripnriprod
bluhaven wrote:
I assumed I was going to have to pull the bracket off but didn't have to, took the leg off and straightened the bracket on the camper.
Kevin
That's what I was able to do. Only bent the part attached to the leg, not the bracket section on the camper.
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
bluhaven
Kevin
Joe417
On my brackets they used some type of rubber based sealer between the bracket and the fiberglass. It isn't silicone or butyl. Similar to the clear Geocel sealer except white.
The metal to metal connections(leg to bracket) were sealed with silicone.
Joe and Evelyn
Super_Dave
Congratulations for getting out of that mess un-charred. It looked awful on the news. My brackets are all caulked. There's no "glue" that's going to hold a jack bracket in a structural fashion. Straighten the bracket, bolt it back up and caulk to prevent leaking into the frame.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
