โFeb-27-2020 06:17 AM
โFeb-29-2020 08:56 AM
โFeb-29-2020 08:42 AM
machunt wrote:
From what i can tell my 2013 may not have a t stat built in. mine has just the normal 3 prong plug, from pictures i see the stat is built into the plug correct?
โFeb-29-2020 06:39 AM
โFeb-28-2020 10:35 AM
machunt wrote:ktmrfs wrote:ScottG wrote:machunt wrote:
can we just stay on topic, all i want to do is check my cord or my heater its self to see which is bad. and i dont have a fancy plug with a element on it. just a simple 3 prong male plug
ON the first page, 2003Silverado gave you the answer.
Plug it in and look for a spark as you do so.
Are you not getting a spark? If you are, it's working.
But if no spark , doesn't mean it isn't working!!!!!
for the 2003 that works. For later models, not a good indications. Somewhere between 204.5 and 2015 GM added a thermostat in the block heater circuit so it won't turn on above a certain temp, somewhere around freezing. So the plug in and check for a spark above that temps is going to head you in the wrong direction!!!!
โFeb-28-2020 09:27 AM
โFeb-28-2020 08:39 AM
โFeb-27-2020 06:01 PM
โFeb-27-2020 03:19 PM
โFeb-27-2020 03:16 PM
ScottG wrote:
There's really no way having it plugged in can make it harder to start.
If you're having to crank it more, you may have injector, HP pump or something else causing pressure issues.
โFeb-27-2020 12:43 PM
machunt wrote:Ok, then get out your voltmeter, but I already replied with the easiest thing.
โFeb-27-2020 12:39 PM
smarty wrote:I live in NM. Was 15ยฐ overnight last October 10.
I found a way to get rid of my block heater....moved to new mexico ๐
โFeb-27-2020 12:11 PM
โFeb-27-2020 11:06 AM
โFeb-27-2020 09:28 AM
