Brake Pads
maxwell11
I have a 2005 Dodge Diesel 2500 Quad cab short bed, 80K miles
I purchased new brake pads:
Wagner Thermo Quiet
Made by Federal Mogul
Have any of you guys used these brake pads,
If so, how did they perform?????
Cost about $95 out the door with tax.
36 REPLIES 36
Cummins12V98
Just wondering why ask how a product has performed AFTER you purchase an item?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Perrysburg_Dodg
I bought it from NAPA it's their DOT 5.1 Non-Silicone Brake Fluid . I have flushed the system 3 times since I bought the truck. The guy at NAPA said the DOT 5.1 has a higher boiling point then the DOT 4.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
BenK
ABS system valves are VERY good, so unless you have initiated ABS, the brake fluid
in the ABS module is still isolated from the DOT5
Silicone brake fluid is NOT tolerant of moisture and will leave it to
pool at low spots. That then will have a high potential of corrosion 'there'
Silicone brake fluid will also aerate easily and will then be held
in suspension if jostled in any way. Why most DOT5 bottles will say to
leave the bottle to sit for an hour or so before pouring into your
vehicle brake system
It used to be a DOT4 vs DOT5 discussion, but now that DOT5 comes in
glycol, it now a glycol versus silicone discussion. There is also a
DOT5.1 (glycol and for ABS systems having mechanically cycling
proportion valves)
Glycol based brake fluids are some of the best paint removers known
and silicone is safe on 'most' painted surfaces
So Don, check the bottle and if no longer have them, the brand and
spec of the DOT5 you used. Am hoping it is glycol DOT5
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Perrysburg_Dodg
Well I have to say no, I only flushed the main lines. Opened the RR bleeder until clear fluid came out then the same for the LR, RF and LF.
Don
BenK
Careful on DOT5 on vehicles not designed for it
Changing *ALL* of the seals and soft materials is a must....along with a complete flushing
Then the issue with the ABS system seals and soft seals and materials must also be changed
It would be easier to get an ABS system made for DOT5 than try to change those seals
Not all Track stuff are a good thing for street
Don, did you also flush your ABS system ?
Perrysburg_Dodg
maxwell11 wrote:
it was for all four corners
may be a little high but I wanted a good set of pads,
in the pass I have had the long last super hard pads, but they made noise, I did not want that.
when pulling that travel trailer, I just wanted brakes in good shape.
just thought it best to ask before I had them installed.
do any of you change out the brake fluid? truck is 14 years old!!!!
NAPA's top pads, rotors and calipers are what I'm running and I'm very happy with them and how they stop.
Yes change the fluid out with DOT 5 brake fluid. But you MUST change or remove ALL of the old fluid first! You can pick up a brake vacuum pump from Harbor Freight. Click me this is what I use works great.
Being it is a 05 you might want to replace the soft lines. I rebuilt my brake system last year including all the soft lines and the pedal is rock hard. If you change them you won't believe the difference it will make!
Don
Oh well should have read the whole thread before I posted. ๐Ÿ˜ฎ
maxwell11
had the pads installed this morning.
sure made a difference in braking.
mechanic said the front pads were almost gone.
so far no brake noise, stops good,
BenK
Forgot...going too high in performance will have some liabilities you will need
to consider and manage
I went with Performance Friction carbon when they first came out. He's a buddy of
John at Praise Dyno Brake. Both used to work at, think IIRC, Holly or some such
Anyway, they were GREAT when hot, but when cold...slide right through a cross
walk in front of an elementary school. Lucky very early and if later...it might
have been filled with kids
Friction material *ALL* have a working temp range. The higher performance they
are, the higher the lower end of their working temp range. Those good at the lower
temp range will have a lower high end range. Some mix and match to try and get
a wider temp range, but a compromise at best on the ones I've tested
BenK
path1 wrote:
snip...
Out of curiosity, What point are you supposed replace pads?
I think I'm getting down there but not sure when to replace.
Any surprises putting them on?
First, which pads is so dependent on how you drive, where you drive
and what you tow/haul. Choices range from freebies that comes with
rebuild calipers to performance to pure racing. I'm in the performance
to racing with racing prototypes from buddy I test all the time
On that, recommend folks test their ABS about once a month. Find a
gravel or loosey goosey pavement with no traffic and nail them. Wakes
up most ABS systems
Purchase based on cost, generally. The more expensive generally are
better than the cheaper ones. Your decision based on how you drive
and maintain your vehicles. Mine normally list for over $100 bucks
but get discounts (AAA at NAPA, and got to know lots of the folks
at various supply shops and buddies who are always formulating stuff)
Friction material's thermal characteristics has them out gas when
at a certain temp range. That will float them off the cast iron and
is what 'fade' mainly is
Their ability to reject heat to the backing plate and then to the
other thermal pathways to reject is one key
If the friction material is too thin, it will NOT have enough thermal
inertia to both radiate and transfer heat to the backing plate
That will then have the friction material heat up quickly and out gas
A bad thing
Most of today's pads have "squealers' on them to make a squealing
noise when they touch the rotor. Most are only on one side of the
caliper and is the piston side, which wears faster than the anvil
side. Most has the piston side on the inside and the anvil on the
outside and that is mainly for clearance for the wheels (the stuff
like hose, banjo, bleeder, piston cylinder, etc)
I normally change mine before the squealers contact and depends on
which vehicle.
Just changed the mini van and still had a bit to go before the squealer
touches. Noticed that braking was lessened and with the level of
performance pads...made a ruckus...like gravel on the rotors once
they came up to temp
For the mini van I buy from NAPA and found a new performance level
I like a lot for 'cars'. Nissin is the brand
For the Silverado still have Praise Dyno Brake front and rear. Great
stuff out of Texas and GREAT folks (love that family run business)
Suburban has buddies prototype and will have to give them back soon
for him to check out in his lab
The Sub's rear are Praise Dyno Brake shoes and think around +100K miles
of SEVERE duty on them
On any surprises...depends, but most today are very similar in architecture
So they pretty much all go through the same sequence
Key is making sure the sliders are working FREELY. I have my own setup
to inject high temp disc brake grease (loaded with Moly). I always
replace the slider boot...if they are available.
I also bleed the lines each time I change the pads. Use the 'C' clamp
method and can do it alone without the need for a helper
APT
I love Wagner Thermoquiet pads. I have used them on all my vehicles for the last 5 years. If you have an Advanced auto parts in town, you can save 20% by ordering online, coupon, and in store pickup.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
45Ricochet
thomasmnile wrote:
Yes I do. My mechanic has performed a complete purge/refill of the brakes system. He tells me this service performed occasionally is cheaper than replacing an ABS module. And I agree.........
I do also about every three years. OEM pads here but I have a EB.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
fj12ryder
JustLabs wrote:
fj12ryder wrote:
That's a good price for all 4 wheels, kinda high for just the fronts.
I was thinking its a high price for pads,even for all four corners.
I've use the Thermo Quiets. Decent pad,middle of the road.
IIRC I saw a $30 rebate on Wagner pads while at the parts store the other day. You may want to check it out.
You might be able to get them cheaper online, but local O'reilly's price is around $65 per axle. So $95 for both axles is a pretty good price IMO.
Howard and Peggy
"Don't Panic"
fj12ryder
If you want to judge by the thickness of the remaining pad, you need to know if they are riveted or bonded. Riveted pads must be replaced while there is still more pad remaining to avoid scoring the disc with the rivets. They should usually be replaced when there is about 1/16" material left on bonded pads or 1/16" above the rivet head on riveted pads. Many pads have a clip on the end that will contact the disc when it's time to replace. If your state has safety inspections, the mechanic will usually let you know when they are getting close.
Does anybody even make riveted pads anymore, other than for commercial usage I mean? All I've ever seen are the bonded, i.e. glued. ๐Ÿ™‚
I usually replace mine when the material is getting thin. No sense waiting until it's gone completely. Pads are just too cheap to warrant running the risk of ruining the rotors. Although those are pretty cheap too. LOL
Howard and Peggy
"Don't Panic"
maxwell11
{my truck is a 2005 model and is 14 years old}
that is the new "common core" math they are teaching today.
do not know where I got that figure, it's wrong, I am just old, did not check my figures, before I hit the post button.
but, back to the brake pads, at least, so far no negative reaction.
sure do not want the brake pads to turn out like the Cooper tires I bought for my van, what a unhappy camper I have been since buying those tires. sure wish I had ask others about those tires before I laid down my money.
An for a few dollars more, I could have had another set of Michelin's. But she said, she might trade it at 100K and I did not want to buy someone else a new set of Michelin's. it needed tires and I got them, wow.
DavisK
2013 Silverado 2500 HD LTZ CC 6.6L Duramax Diesel
2014 Sunset Trail SF270BH
Holly & Buster, rescued mini Dachshunds
