Apr-21-2014 07:36 PM
Apr-27-2014 07:50 AM
Apr-26-2014 04:32 PM
Apr-26-2014 11:41 AM
Apr-26-2014 10:30 AM
Apr-25-2014 08:18 PM
Apr-25-2014 07:12 PM
maxwell11 wrote:
it was for all four corners
may be a little high but I wanted a good set of pads,
in the pass I have had the long last super hard pads, but they made noise, I did not want that.
when pulling that travel trailer, I just wanted brakes in good shape.
just thought it best to ask before I had them installed.
do any of you change out the brake fluid? truck is 14 years old!!!!
Apr-25-2014 05:47 PM
Apr-22-2014 10:46 AM
Apr-22-2014 10:40 AM
path1 wrote:
snip...
Out of curiosity, What point are you supposed replace pads?
I think I'm getting down there but not sure when to replace.
Any surprises putting them on?
Apr-22-2014 10:11 AM
Apr-22-2014 09:18 AM
Yes I do. My mechanic has performed a complete purge/refill of the brakes system. He tells me this service performed occasionally is cheaper than replacing an ABS module. And I agree.........
Apr-22-2014 06:46 AM
JustLabs wrote:You might be able to get them cheaper online, but local O'reilly's price is around $65 per axle. So $95 for both axles is a pretty good price IMO.fj12ryder wrote:
That's a good price for all 4 wheels, kinda high for just the fronts.
I was thinking its a high price for pads,even for all four corners.
I've use the Thermo Quiets. Decent pad,middle of the road.
IIRC I saw a $30 rebate on Wagner pads while at the parts store the other day. You may want to check it out.
Apr-22-2014 06:43 AM
DavisK wrote:Does anybody even make riveted pads anymore, other than for commercial usage I mean? All I've ever seen are the bonded, i.e. glued. 🙂path1 wrote:
If you want to judge by the thickness of the remaining pad, you need to know if they are riveted or bonded. Riveted pads must be replaced while there is still more pad remaining to avoid scoring the disc with the rivets. They should usually be replaced when there is about 1/16" material left on bonded pads or 1/16" above the rivet head on riveted pads. Many pads have a clip on the end that will contact the disc when it's time to replace. If your state has safety inspections, the mechanic will usually let you know when they are getting close.
Apr-22-2014 05:26 AM
Apr-22-2014 05:13 AM
