Brand new Kodiak trailer - can't use toilet
IdahoRVing
:C
53 REPLIES 53
IdahoRVing
:C
IdahoRVing
:C
aftermath
At times like these it is hard not to go ballistic. I would request a new trailer or full money back. I would also try to find a lawyer friend to write a letter. This is totally unacceptable and having a black tank that you can not drain completely is not a solution.
Good luck. Might be time for the squeaky wheel to get louder.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
midnightsadie
time for an att. just my .02 cents worth . your dealer did work without approval and now the factory ain,t gonna step in.
IdahoRVing
:C
azrving
Is the tank misaligned so the hole isn't lined with the toilet? Is that a "knock out" piece of plastic stuck in the pipe? Can you remove the tank and see wth is going on?
RedRocket204
Could the black tank be slightly moved to where a 45 off the floor flange could plumb properly into the black tank? I tend to think there is probably not enough room to shift the black tank to get the room to do that.
I love me some land yachting
K-9_HANDLER
OP, sorry to hear ur troubles. Please keep us posted.
Camping near home at Assateague National Seashore with our wild four legged friends
K-9_HANDLER
DutchmenSport wrote:
K-9 HANDLER wrote:
Uh wow
Dutchmen is that the OP's tank pic?
Yes. I had to work fast to get them before the "Link Removed" happened. But yes, they are both his.
Thanks I never did see that second pic till u got it posted.
IdahoRVing
:C
DutchmenSport
K-9 HANDLER wrote:
Uh wow
coolmom42
What does your dealer say about it?
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
RedRocket204
IdahoRVing wrote:
Thank you!
Anybody else just not see that working out??
You are obviously over reacting... ๐Ÿ˜‰
gotcha.
Yeah, a poo pyramid would block that quickly.
K-9_HANDLER
Guess it is. No what Im seeing in the pic with the tape measure wont work.
K-9_HANDLER
Uh wow
