I have a Reese POD controller that was previously installed in my 2004 TB. There it worked fine with no issues ever. When I connected the trailer wiring the indicator on the conrtoller would glow green and depending on how the breaks were adjusted would turn orange or red when they were applied. In the fall I moved the controller to a 2007 Suburban and just towed for the first time an had a lot of trouble with it. First the green light would not come on then when I finally got it to and drove it kept flashing on and off for about 5 miles then stayed on and worked properly except when I applied the breaks fully at a stop they stuck until I tapped the pedal to release them. When coming home the controller came on first but then would shut off as I applied the breaks but same thing after a few miles it came on steady and worked except that I had to tap the pedal to release the breaks. Does anyone have any ideas? Could moving the controller have shorted it out or damaged it in some way?
Me - PSU 1999
Wife - Also PSU 1999
Daughter - Hopefully PSU 2026
Daughter - Hopefully PSU 2029
Twin Daughters - Hopefully PSU 2033
2015 Keystone Summerland 2980 BH TT
2007 Chevy Suburban TV
