breaking in brakes...what do you do
Lessmore
Just had all the brakes done on my vehicle. Vehicle brakes, as we all know are very important on vehicles, but IMO....more so on a tow vehicle.
How do you break in your tow vehicle brakes ?
I'm always hoping to learn new things....even though I am an old dog.:)
24 REPLIES 24
Turtle_n_Peeps
Grit dog wrote:
If just replacing pads without turning the rotors, I always scuff up the rotors real well with some med grit emery cloth. Figure that helps bed the brakes in quicker.
This ^^^^^^
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Grit_dog
Navigator
Navigator
mhsmith
Engineer9860 wrote:
I have always "bedded" my new brakes. I have never replaced a rotor on anything that I own.
My '97 Blazer still has its original rotors/drums at 280,000 miles, so I must be doing something right.
I guess it is typical of a few RV.net members to ridicule anything they read on here, but brakes are nothing that I take lightly.
I have to ask-with that mileage-have you ever measured the thickness of those rotors and checked them against machine-to specs or discard specs? They do "wear" also.
BenK
There is much more to braking than just having the ability to skid
the tires if no ABS....if you do have ABS...to then initiate ABS,
which has many attributes other than just cycling MC PSI to keep
the tires from stopping or slowing down to skid
Modulation is my main requirement with a very close second of thermal
characteristics
OEM to mud hen friction materials can skid/ABS the tires and again there
is much more to it than just that
But, generally that is all folks think is it and all they want. Okay
too, as that is the expectations...but not mine. Mainly because
consider braking of higher importance over acceleration and ultimate
speed...though am still a boy racer that also loves it
Modulation and the shape of the braking curve go hand in hand.
I can out stop a similarly setup 1996 Suburban (GMT400's have poor
to bad brakes, but can be made to be good to almost great...another
but it takes constant tuning) because I don't allow my Sub to go into
ABS...unless I've gotten into a situation where I've no other choice
than to nail it to the floor
Real experience, as going through an intersection one morning while
the pavement was wet from early dew...a Land Rover jumped his stop
sign thinking I also had one...nailed the brakes to find that the
pavement could not support that kind of braking. So ABS kicked in
and seemed like accelerated, but know just stopped decel and continued
at whatever speed (under 20MPH by that time...was going 25MPH)
Hit (glancing) that guy and almost ran into the Honda on the other
side of the intersection.
ABS initiation has 'less' braking than the point just before ABS
turns on. That is where I modulate it to be, or try to
Without properly bedding in 'my' brakes, their braking curve looks
way different. Haven't, nor the instrumentation to do so, but know
how it looks via the feel because did purposely NOT bed in a set
of proto-types tested for a buddy. Other set did bed in
Learned much on that in an oblique way while still in college and
working part time as a designer in a Industrial controls company
Was assigned to design to a DOT specification for a tire test stand.
One of the first solid state (up till then, they had hydraulic)
dynamometer's for this
We were 2nd contractor to the dynamometer builder, we did the controls
and electric motors
Tires of old also have a similar break in vs performance. Tires today
do not as much, but they still have 'some' break in requirements or
attributes
With all that, goes back to a previous comment that bedding in is
for the purist of braking or high performance
So, just understand that there is a difference, but then maybe most
folks won't bother nor notice the difference...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
ksss
I had Hawk SD pads and EBC rotors put on my 3500 last year. Hawk had a process they wanted you to follow after the install. A couple stops from 35 mph and one from 60 as I recall. Someone could look it up if they so desired. I did it as they instructed. Don't know if it makes a difference (great brake combo by the way)but I did it.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
time2roll
I could not find anything in my Ford F150 manual but I have read something similar to what Les posted. The "go easy" for ~200 miles is what I follow.
180,000 on original rotors.
Lessmore
BenK wrote:
Hey Lessmore...please post a picture of the glove box manual page on HOW2 break in
the braking system
I'd love to see what it says
Ben, sorry for the wait.I don't know how to post photo's to the computer, but I will quote you the passage about break in of brakes in the GM Owner's manual.
" Avoid making hard stops for the first 200 miles or so. During this time your new brake linings are not yet broken in. Hard stops with new linings can mean premature wear and earlier replacement. Follow this break in guideline every time you get new brake linings. "
Les
BenK
X2
and that so many only think 'performance' is quickness and ultimate MPH
JamesBr
The stoptech bedding process really is meant for a WAY more aggressive pad then a street car or truck usually would have. I use a similar processes as the one posted for the my weekend fun car with an aggressive pad, and a more extreme for the race car (during on tract practice, not the streets.) Any street car, all you need is to drive it and give yourself a little extra stopping distance for the first couple of days of driving have always worked well for me.
Rotor wear was also mentioned, really it depends on the brake material and how aggressive it is....the more aggresive the faster it will wear through a rotor. I have a 98 S10 similar to the mentioned blazer where I put on new rotors when I aquired the truck and 140k miles later still running the same rotors, but on the 3rd set of pads (DC area commuting.)
On my weekend toy/track car im lucky if I can get 2 sets of pads on one set of rotors and those pads last a few track instruction weekends or about 20k miles. The race car....4 races and the whole setup is toast....its all bout the compounds.
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
ianmac23
I have been in the SCCA for several years and most people I know that take their car on the track will bed their brakes. It is the safe way to insure your brakes will work right every time. I have always done it and never had a problem with my brakes. Before I met my wife she warped rotors all the time and now she does not.
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
Engineer9860
In Memoriam: Liberty Belle
Ron3rd
downtheroad wrote:
Ok, for all you naysayers to my post above about properly bedding new brakes, If you don't follow this procedure exactly you are risking the safety of your family and everyone else on the road...
Seriously, I never said I did all this...it's for the "purist."
New brakes: Personally, I just drive normally and get on down the road.
The instructions you posted are included with Hawk pads. Makes sense to me.
Equilizer Hitch
Honda EU2000
BenK
the braking system
Lessmore
smkettner wrote:
Owner's manual may cover it. Brake moderately and avoid panic stops the first ~300 miles. Of course if you must hammer the brakes to avoid collision... please do.
I think this one might be the easiest and probably the most effective method.
Thanks for the advice everyone.
