Aug-15-2013 09:31 PM
Aug-23-2013 03:25 AM
2Gordons wrote:
Good info, Thanks! Did you use a spicific sealant to put the trim ring back in place, or how was that step accomplished?
Aug-22-2013 11:06 PM
Aug-22-2013 08:30 PM
portscanner wrote:
Well it is done!!!!!!!!!!!!!
For those who are interested, there was a rubber trim that is wedged in all the way around the window. I just pulled that out. Then using a razor blade I cut the glass loose from the goop holding it in place. A combination of a putty knife, mineral spirits and paper towels removed all the old sealant.
K&S Glass Company in Newnan, GA supplied me with a piece of 0.250 Lexan cut to size - including the radius corners - for $80.31. Add in a tube of 3M 08509 Auto Bedding and Glazing Compound for $12.34 and I had all the parts I needed. I applied a 1/4" to 3/8" bead of the 3M08509 (or maybe a little larger - I am not the best w/ a caulking gun), lined up the window and dropped it into place. I pressed it in to make sure it made a good seal, then put the rubber trim back in.
Thanks to everyone for pointing me in the right direction
I want to add an extra thank you to BobsYourUncle for his additional support and information!!!
Aug-22-2013 04:56 PM
Aug-20-2013 02:19 PM
Aug-20-2013 12:49 PM
Aug-20-2013 12:16 PM
Aug-17-2013 10:17 AM
travelnutz wrote:
For the OP:
A major supplier of Lexan and Acrylic sheets in the East half of the U.S. is/was Cadillac Plastics. ...
Aug-17-2013 08:35 AM
Aug-16-2013 10:55 PM
Aug-16-2013 05:46 PM
Aug-16-2013 10:08 AM
bobndot wrote:
I try to take notice of materials used when work is being done , just to learn and compare methods that people use.
When i watched an rv mechanic replace one, he used a gasket and then 3m flow butyl.
As soon as the job was finished, he was able to water test it right away.
http://www.glasswarepro.com/key/3-M-flow-grade-butyl-sealant
Aug-16-2013 08:54 AM
Aug-16-2013 06:47 AM
