Bypass for water heater
Npdchief07
I have a 2019 Wildwood 261bhxl and can't locate the hot water heater bypass. Any ideas? I figure it would near the bottom bunk but can't locate access.
9 REPLIES 9
ret_usn
I assisted a camper on one of my trips. we actually had to remove the inside lower cabinet wall. It had screws and was removable.
2004 R Vision Trail Lite
2003 F150 Super Crew
Old-Biscuit
Seeing as your Suburban Water Heater is installed at rear of trailer it should have an access under the rear bunk bed..a removable panel/floor section etc. Might have to pry it up if stapled down
OR might be accessible via outdoor kitchen compartment(if optioned)...remove drawer etc
Lynnmor
Dick_B wrote:
Being of simple mind I like the bypass arrangement that has three valves so it is obvious where the flow goes.
Shut off the valves at the Water Heater and open the bypass valve for winterizing. Reverse the valve positions for normal operation.
But then you miss out on the buzz and squeal from the check valve, not to mention the fun of replacing it when it fails. Also, the check valve saves some hot water when it reduces the flow.
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
downtheroad
Sometimes it's considered an option and not automatically installed.
Here is a basic system that is very easy to install.....available at Amazon, most all RV dealerships, Walmart, etc....
Water heater by-pass...HERE
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Mfan
Does it have one?
Bobbo
Did you look on the back of the water heater?
Bobbo and Lin
sch911
It's always behind the water heater.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
NascarBobnBeth
it should be right by the waterheater
