Camper jack switch?
candjmc
Hi all, we got rid of our bigfoot camper the lay out was terrible.
We have found a better camper for us.1994 okanagan 10'i don't like the hydraulic jacks I just don't feel safe running around jacking here and there ect.I want to change to electric jacks. Has anyone else done this swap?
5 REPLIES 5
candjmc
Ok thanks I was even thinking about just running the wire on the outside in some sort of conduit cover they make lot's of different stuff.yes sounds like its not to bad to do .I definitely don't want to spend the money on anewer modern camper as the money is a bit tight. I have seen sets for about $2500 any advice on where to get the best pricing ect would be great
Tamnative
I did it on an older Lance. Before you buy anything make sure you can get to all the corners for the wiring and the mounts. Get it all planed out before hand.
2005 Ford F-350 ex-cab Lariat 4x4 srw 6.0 Powerstroke
2008 Bigfoot 10.4
Butch50
You well need to get new jacks, controller and wire the camper up for them. There is no way to use the existing jacks as far as I know. I agree with you about not liking the hydraulic jacks. I had them and they just get very tiring to pump on one then run around and pump on all the others.
Butch
I try to always leave doubt to my ignorance rather than prove it
2021 Winnebago View
Driftwood132
I went from 4 manual roll up jacks to 4 electric jacks ,non remote but so much easier then the others. Now if I recruit my daughter she and I can have the truck camper on or off the truck in less then 5 minutes.
Super_Dave
Depending on the jacks you have, it can be done by simply adding jack motors to your current jacks. And of course, worst case, you unbolt and rebolt on new jacks and run the wiring. The wiring is not difficult.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
