Camper tie down inserts
cgilde
Just purchased a 2004 Dodge Ram 3500 from a dealer to haul my truck camper. I was surprised to find leaf springs already had stable loads on both sides. I also discovered I may not have to purchase torklift tie down brackets. It already has the brackets mounted to the frame. However, no tie down inserts. Is there any way I can purchase the inserts only? I searched the torklift site and came up with nothing. Where would I buy tie down inserts only. Anybody else have similar experience? Any advice would be greatly appreciated.
8 REPLIES 8
996Pilot
I PM'd you - check your messages.
Dan
2018 Arctic Fox 811
2015 RAM 3500 SRW Laramie Longhorn 6.7 Cummins 68RFE Timbren SES, Lower Stableloads
2006 Dodge Ram 2500 Laramie 5.9 Cummins 48RE TRADED
2006 Outfitter Apex 8 TRADED
Tom_Anderson
You can also send a PM to user "Torklift" on this forum.
shellbackcva59
Why not check with the dealer you bought the truck off and see if he could contact the previous owner. He may have them laying on a shelf.
pcoplin
If you need straights ones, I have a set of these available.
2005 F350 CCLB Dually 6.0/5R110
2009 Adventurer 950B
bb_94401
Call Torklift they sell the inserts individually.
Make sure you locate the square head wire locking pin on the top. If on the bottom it can be accidentally opened, if you drag it over a log and lose your insert ...
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake, Roadmaster bar
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
Old_Days
If you can not find any just go to a welding shop and have them made,shouldn't cost to much.
Old_Days
I have a set of them, but I live to far away. I would go to craigs list and put a ad there.
Grit_dog
Navigator
Navigator
Just sold a spare set with chains and turnbuckles for $50 on Craigslist.
I'd look there. Or call Torklift central and see if you can purchase just the inserts.
