Can shower curtain be replaced with glass enclosure?
dnhx
HI,
We are looking at a new trailer that has a neo angle shower with shower curtains. My wife hates the shower curtain. Is it possible to add without changing the shower pan? Are there any sort of glass enclosure shower kits made, or would it have to be custom made? (We are looking at the Lance 1995).
DH
Dallas,TX
8 REPLIES 8
Dick_B
Does she hate the curtain or the idea of a curtain. If the former check out my previous post:`If your flimsy show curtain gets sucked in when showering an easy fix is to buy a better/heavier shower curtain. We buy one with a clear top to allow in light. It is sold by Hospi-Tel and is their Clearview line.'
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
352
I put in a bowed to the outside of the shower curtain rod. Self made . Although you can buy them. The rod stuck out about a foot on the radius. Made with PVC and PVC T's. Cheap. No more shower curtain sticking to the but.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
mosseater
Ours came with a sliding glass door and it's been great. The track tends to gather dirt and soap scum, so that needs cleaned out periodically, but other than that it's been really nice. Just make sure it's secured when travelling. I put a bread tie on the safety catch as well as drape a shower mat across the track in case the latch fails. I don't see why it couldn't be fit to any standard shower/tub.
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
My_Roadtrek
Lance uses the curtain because the.doors get hit a lot with body parts. The curtain allows for more, elbow room. I would stick with curtain in a Lance. jmo
Houston_Remodel
We have a quarter circle accordion curtain that works very well. Its one reason we purchased this TT and not one with an ordinary curtain.
If you're lucky a quarter circle curtain might fit if the top of your curb is wide enough, or you don't mind the circle overlapping the shower floor at the inside corners of the neo angles.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
Margos_
Our shower has the glass wall and door and I kinda like it. I keep thinking of what will happen when it breaks. Have heard of others breaking while going down the road. Time will tell.
midnightsadie
to get the facts I,d get a hold of lance.
Bumpyroad
ask Lance if they will retrofit one.
bumpy
