May-26-2015 03:53 PM
May-28-2015 07:30 AM
May-28-2015 06:11 AM
~DJ~ wrote:
I would do option 1. By the time the sun got low enough to cast a shadow over the panels from the box you're not getting enough sun to worry about.
Then you have to decide if the box is sturdy enough to hold a panel in 60 mph winds!!
May-27-2015 04:36 PM
May-27-2015 02:10 PM
anutami wrote:It isn't when you took that picture.
First option: will this cause a major issue with my solar panels casting a shadow
May-27-2015 02:09 PM
May-27-2015 12:43 PM
May-27-2015 11:32 AM
May-27-2015 10:23 AM
May-27-2015 09:59 AM
Reddog1 wrote:anutami wrote:I am not sure that this would cause a major shadow, Wayne
May-27-2015 08:47 AM
anutami wrote:I can tilt my panels, but after testing I have found it not worth the trouble. As for mounting on the box, you could but that would not be my first choice. If I understand correctly, the panel would be mounted to a plastic lid which if not latched properly could launch the panel. Every time you open the box, you run the risk of damaging the panel.
I've decided to use a cargo box and wanted to get different opinions if it is possible to mount a solar panel on top of the box to elimate the "shadow" effect on my panels. The box also opens up on each side So I could tilt the panel to get it in the right direction to the sun.
anutami wrote:I am not sure that this would cause a major shadow, if the box when closed position. Personally, if I had my mind set on location the box where it is in the photo, I would give it a try. The sun would be pretty low for the box to cast a shadow. I would consider raising both panels 2 to 3 inches. Looks pretty simple to do. If you park your camper with the driver side to the south, probably no problem at all.
anutami wrote:I do not like this option. see above as to why.
Second option
anutami wrote:I must be missing something here. Why would you need the box open other than when you are getting something out of it? Your verbiage does not match your photo. Panel inside the box?
Third option: just go with the shadow effect since it is a losing battle anway
anutami wrote:
Fourth option:
Mount the panels on the cabover portion of the TC. I am hesitant to do this because
1. Need to drill more holes again into the roof
Not that big of a deal. Original holes are easy to caulk.
2. Putting more weight over the cabover area.
Not enough added weight to be considered a problem.
3. wires laying exposed on the roof
If properly clamped, not a problem at all. My TC solar wiring has been exposed on my roof for over nine years.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
May-27-2015 06:24 AM
May-27-2015 05:33 AM
May-26-2015 05:08 PM
May-26-2015 04:35 PM
