โAug-13-2018 12:59 PM
โAug-19-2018 01:29 PM
Kayteg1 wrote:
The linked Ford is no longer available, but look at This classic
Those things could do real bumper pull as well.
Front bumper push as well.
โAug-19-2018 12:43 PM
โAug-19-2018 10:13 AM
โAug-19-2018 10:05 AM
Once you said the axle was 1/3 from the rear, or 16" difference, now you are saying 7", so which one is it?
โAug-19-2018 09:17 AM
burningman wrote:
Since youโre doing math you might as well use the correct numbers.
The old Super Camper Special has the rear axle moved 7โ further back.
Wheelbase was 140โ.
They were also better for trailering than the regular cab F250 with the standard axle placement.
Just that seven inches makes a significant difference. Try sliding your camper back 7โ and driving it. A crewcab diesel might not be affected but if you have a regular cab gas engine truck like almost everyone in that truckโs day, youโll notice it plenty.
โAug-19-2018 08:12 AM
โAug-19-2018 07:34 AM
โAug-18-2018 03:06 PM
trail-explorer wrote:
This thread is turning in to another disaster
โAug-18-2018 10:34 AM
Kayteg1 wrote:
Not to mention that 15k GVW makes it commercial in some states, what makes requirement for replacing engine every 20 or so years.
โAug-18-2018 10:14 AM
jaycocreek wrote:My dually axle is rated at 9900lb.
That ain't much more than the old Sterling 10.5(9750)...I thought Ford would have upgraded more than that by now..
Shouda bought a Chevy..(laughing)
โAug-18-2018 10:10 AM
jaycocreek wrote:I've never seen a wire harness with legs. Did it tried to walk away since it had so many legs?
I don't know about the legs but,have you or anyone else ever seen a modern SRW 3500 rated for 5,000 pounds payload?...Heck,half the duallies aren't rated for that!
So,COG must matter to Ford in the old days.
โAug-18-2018 08:51 AM
Kayteg1 wrote:
Well the 5000 lb camper puts 5200 lb load on modern truck rear axle, when on the old camper special it would be let's say 3500 on rear axle and 1500 on front axle.
It does make big difference even now everybody wants CC, 4WD, sunroof etc.
โAug-18-2018 07:48 AM
Trucks have as strong or stronger chassis now, but the empty trucks weigh 3000 pounds more than say a โ75 Super Camper Special did.
โAug-18-2018 07:30 AM
โAug-18-2018 04:52 AM
