Cold weather camping and sweating in closet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โJan-26-2015 05:47 PM
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โFeb-07-2015 09:08 AM
Most people at the park I stay at use a dehumidifier. I bought mine at Home Depot for $150ish. I run the thing all day and all night.
I pull about 2-3 gallons of water out of the air over a typical weekend. That is moisture that would cause mold or rot.
If you are going to camp in the winter or colder months, you are going to need one.
2012 Jayco Eagle Super-Light 314BDS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-27-2015 11:06 AM
TomG2 wrote:Not on a stick and tin TT... But on a fiberglass,,,, yes and a lot. I have a meter that measure humidity, and can see the difference. That is a good thing as the stick and tin TTs don't have potential for delamination.
Given the porosity of a typical trailer, I wonder if a humidifier would be able to red uce the moisture much? The other suggestions will help.
Wiping down the windows is NOT a solution. The same condensation is happening inside the walls... Given enough time, delamination WILL result.
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-27-2015 05:40 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-27-2015 04:55 AM
Oh, and ScottG, thanks for the tip on checking my pulse! Funny!
George Burns
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-27-2015 02:46 AM
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-27-2015 02:20 AM
2007.5 Chevy Silverado 2500HD 6.6L Duramax Diesel, Air Lift
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-26-2015 09:00 PM
I use a dehumidifier. It pulls an incredible amount of water out of the air. All that water would be on my walls and windows with out it... BTW, sweating shows up first on the windows, when you see that, take some action NOW!!. Cracking the closet doors is a good thing, no matter which method you use to control the condensation. But be sure to DO SOMETHING. My Forest River manual has warnings about this subject, I am sure others do as well.
100% boondocking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-26-2015 08:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-26-2015 06:21 PM
Takes a bit more propane for heat, but you can leave a window or roof vent open just a crack.
Leave cabinet doors open and pull things away from the walls to let air circulate. If this is going to be a frequent thing, maybe a dehumidifier would be in order.
I have a small dehumidifier that fits on the counter. It has a shutoff when tank gets full. I modified the tank, with a hose to drain into the sink. I still need the open doors and such.
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-26-2015 06:18 PM
You have a fraction of an inch of air that is part way between exterior temps, and interior temps. This is where your sweating is occurring. Either reduce airflow to the area, and move the problem to the closet doors, or increase airflow and attempt to prevent it from happening in the first place.
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-26-2015 06:17 PM
If the condensation stops, check your pulse.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJan-26-2015 05:58 PM
