โNov-08-2017 08:17 AM
โNov-12-2017 04:32 PM
Ralph Cramden wrote:itguy08 wrote:fallsrider wrote:Lynnmor wrote:
Windshield washer fluid is cheap and wonโt slush up like the pink stuff.
That's interesting. My experience with windshield washer fluid is that on cold mornings, the fluid turns to a glaze of ice as soon as it hits the windshield. What am I missing?
Most of the blue stuff is about 30-35% Methanol. The rest is water. When the alcohol evaporates, the water freezes and that's what you are seeing.
If you dump a few gallons of that stuff in your tank, and the alcohol evaporates out, where does it go? Don't drop a lit butt in there I suppose if your a smoker LOL. May be a pooplosion?
Where are the washer fluid police when needed?
โNov-10-2017 04:46 AM
โNov-10-2017 04:26 AM
โNov-10-2017 02:34 AM
โNov-10-2017 02:33 AM
All I could afford wrote:
Blue washer fluid comes in two types that I am aware of... one kind rated to -20 degrees Fahrenheit, and another that freezes at +32 just like water. Walmart sells both. They market it as summer washer fluid. Make sure the one you use says -20 degrees
โNov-09-2017 05:56 AM
โNov-09-2017 04:51 AM
โNov-09-2017 02:41 AM
โNov-09-2017 01:00 AM
โNov-08-2017 10:02 AM
โNov-08-2017 09:09 AM
mikebreeze wrote:
I live 1 state north of you and I usually camp once a month all year around. I winterized about 3 weeks ago. In the winter I usually take bottled water in a cooler with me and just use the campground bathroom.
Now, if I wanted to use my fresh water tanks while camping in winter I would wrap all of my exposed pipes with insulation or heat wrap tape.
fallsrider wrote:ndrorder wrote:That's a good idea. I'll stop by and pick up a gallon and dump it in the tanks before we leave home.
Dump a half gallon of pink stuff in each tank. Should keep you thawed and juicy until time to dump.
โNov-08-2017 09:05 AM
โNov-08-2017 09:00 AM
bid_time wrote:
I'd get a couple of 5 gal water containers and not use the water system. Done that many times. But that's just me, do you feel lucky?
โNov-08-2017 08:59 AM
