Correct Truck
dixonce
I am looking to purchase a Grand Design Momentum TH 376th. The GVWR is 20,000lbs. The truck I am looking to use for this is the 2017 F350 dually with the diesel. Do have enough truck once loaded with golf cart and necessary camping essentials?
37 REPLIES 37
NC_Hauler
F350 ought to be able to do the job.. oh wait, I own a Ram, and we all know Ram ""Fan
Boys" recommend Rams....:R... So I think the Ford F-350 Dually can do the job VERY WELL!!
Jim
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
drsteve
lawnspecialties wrote:
Are you guys freakin serious? A 2017 F350 will tow that camper all day long without breaking a sweat. Pin weight, overall weight, and whatever else you want to add won't be a problem at all.
Those who think its not enough truck? Maybe you're just not very good drivers when pulling campers.
LOL ... driving ability has zero to do with the towing or payload capacity of a given truck. What a ridiculous statement.
That said, the F350 Dually will tow this 5er with no problems.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
spud1957
donn0128 wrote:
Trackrig wrote:
MFG Web site.
3,250# Avg. pin weight.
Bill
Read that as DRY pin weight.
If you never plan to add anything to the trailer, then maybe. After you load it it? Probably not.
With 20K GVWR that means fully loaded your pin weight could be over 4000 pounds.
A Ram dually with all the towing options might do it.
F350 DRW will have a payload between 5500-7000lbs. Plenty of payload but of course the Ram boys always have to try to convince otherwise.
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
lawnspecialties
cekkk
The F450's max tow with 5th wheel is shown as up to 27,500, max payload up to 7630.
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
1492
Moderator
Moderator
Moved from Forum Technical Support
donn0128
Trackrig wrote:
MFG Web site.
Bill
Trackrig
MFG Web site.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
