1mtnman wrote:
I use Modified Happijac's to connect to my frame mounted Torklift system.
I've purchased longer threaded rods to reach the frame mounted torklift mount. Works fine on my Northstar 850.
I came up a bit shot on the rear as well. I use the front HJ mid bed height mount but I built my rear mounts with square tubing welded to the receiver sides and outboard mounts pinned into them (like the TL mounts) so I came up short on the rear and did like you did with all thread.
The HJ cam lock mounts are substantially less costly than the TL cam locks and work the same and look almost the same. I'm into less expense as long as they work and they do, just fine.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
