Determining what size tarp
rickhise
On a typical 28 footer would like top an both
ends covered, an maybe 5-10 ft of both sides
Covered. Any math guru s what size tarp would
one need?
8 REPLIES 8
nypatnva
I use a tarp just big enough to cover the top and maybe 6" on the sides. Been doing that for years and never had a problem with moisture.
2016 dodge ram
champion generator 1978 Serro Scotty Highlander (restored)
Dick_B
I'd say about 40 x 20 ft. We use a Sunshield tarp with the silver side up in the summer and black side up in the winter where we get snow. Ours is covered all the time unless camping. Never had a moisture problem. We do open the roof vents and crack the end windows to get a little air flow. Search this Forum for `RV Cover' and read on.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
rickhise
Thanks on the demensions
It sits in a 2 sided free standing carport
Ok thanks on getting breathable material
I was trying to avoid direct u v.
So where do I search for breathable material tganks
Lwiddis
โ€œTarpsโ€ are a bad idea. Sit under one for a couple of hours. Youโ€™ll see. Reminds me of my Army poncho...a curse from Sr. Villa. (I know, I know...โ€œPanchoโ€)
Mfan
44 ft x 18 ft. Or there about.
keymastr
A tarp will trap moisture and prevent the breeze from drying it out so you will get mold and mildew. It also will flap in the breeze leaving rub marks all over the rig.
jfkmk
Never use a tarp!
SoundGuy
one need?
None ... you want a breathable cover. ๐Ÿ˜‰
2012 Silverado 1500 Crew Cab
