โJan-17-2017 02:08 PM
โJan-20-2017 05:21 PM
โJan-20-2017 04:10 PM
โJan-20-2017 02:34 PM
TakingThe5th wrote:
New tires - I'm thinking Goodyear Marathon, Maxis M8008, or Michelin XPS to replace my Trailer King ST235/80R16 Load Range E (10 ply) on a 6.5" rim. Comments welcome.
โJan-20-2017 02:30 PM
tinner12002 wrote:
I've noticed since having my TPMS system for pressure and temp that the curbside tires always run about 6-8 degrees warmer than street side. That might be why your curbside tires have ballooned out more than the street side.
โJan-20-2017 08:54 AM
โJan-20-2017 08:51 AM
Turn around and drive west for awhile, the sun can change the temperatures that much or more.
Measurements for alignment, should be taken from wheel to wheel, thus eliminating any variation in tires.
โJan-20-2017 08:22 AM
โJan-20-2017 05:44 AM
โJan-20-2017 03:30 AM
โJan-19-2017 07:07 PM
โJan-19-2017 02:16 PM
โJan-19-2017 05:25 AM
TakingThe5th wrote:mkirsch wrote:
Are you saying the X-chock still won't fit on the curb (i.e. right) side?
You only mention the street side, which you said fit fine before.
The X-chocks were interchangeable. When we discovered the problem on the curb-side, we took both X-chocks over to the street-side to verify that we had a curb-side problem and not a problem with either X-chock. Both chocks worked well on the curb-side.
โJan-18-2017 02:22 PM
TakingThe5th wrote:
So they measured the tires. One pair of tires is actually larger then the other pair of tires. The two tires where the X-chock will not fit add about ยฝ". I never rotated the tires and those are the two that take the most abuse in most turns. The two turns in the driveway are left turns, and I try to avoid blind turns (right turns) when backing up, so the majority of turns backing are to the left.
Maybe not, especially if we are in the early stages of belt separation.
โJan-18-2017 12:45 PM
