โJun-21-2004 09:12 PM
We are getting closer to answers I am looking for etc.
โMar-17-2009 07:37 AM
โMar-17-2009 07:33 AM
โMar-17-2009 07:29 AM
โMar-17-2009 07:21 AM
BertP wrote:dubdub07 wrote:
Can't have one without the other!
Sure you can. Horses don't produce any torque.....dubdub07 wrote:
You point is misleading. If you have 1000hp, you can tow a cruise ship. Torque is how the engine uses that 1000hp. If you only have 350HP, high torque is VERY important in towing.
Why? Hp is HP regardless of what rpm it is developed at.dubdub07 wrote:
Anything less than 400hp will need a very high torque rating, or how efficiently the engine is using the hp and at what RPM does the power come on.
I'm afraid I don't follow that at all. Can you please explain what you mean?dubdub07 wrote:
If you have unlimited use of hp, the torque will always follow the hp. if one goes up, so does the other. They are the same, but different.
Torque does not always follow HP. If I remember the torque curve of the PSD for example, the torque rises up to a point around 2000 rpm and then begins to drop all the way up to its redline. HP, OTOH, continues to rise all the way from min rpm to redline.
Bert
โMar-17-2009 07:09 AM
โMar-17-2009 06:43 AM
BertP wrote:
You should read more of the posts in this thread. Cole's Notes version: you don't need torque to tow a big load, you need HP.
Bert
โMar-17-2009 06:32 AM
โMar-16-2009 08:29 PM
โMar-16-2009 11:21 AM
โMar-15-2009 06:38 PM
โMar-15-2009 06:17 PM
โMar-15-2009 05:35 PM
The 8V71 (or 72) was not used that often in OTR vehicles because it didn't produce enough power.
โMar-14-2009 09:16 PM
BertP wrote:
The 8V71 (or 72) was not used that often in OTR vehicles because it didn't produce enough power. The 8V92, OTOH, was used quite often with a normal power rating of 475HP.
As far as Mr. Lube is concerned, I agree that they can be pulling a fast one. But all I would have to do is have an oil analysis done to prove their wrong doing. I don't think that most dealers would risk the negative publicity that something like that would create. If it would make you happy, I promise to change it myself next time ๐
Bert
โMar-14-2009 08:39 PM
Jarlaxle wrote:You will not fine a V8 diesel in a over the road truck. Detroit Diesel tried it years ago back in the 70's in the over the road truck. It was ok on flat land but had no pull power at all when it came to pulling in the mountains. Detroit Diesel did not keep that engine long at all before they took it off the market.
It was on the market (8V71 and 8V92) for over twenty years. (V6 versions were also built & used widely, especially in buses.) It was only dropped (with the rest of the venerable 2-strokes) after 1992 due to what was basically a 1930's design not meeting new emission standards. For its time, it was as good as any other engine...and an 8V92TA is a powerhouse even today, easily topping 450HP.
โMar-14-2009 08:15 PM
