โMar-14-2014 11:24 AM
โMar-18-2014 01:35 PM
โMar-17-2014 08:48 PM
โMar-17-2014 05:07 PM
โMar-17-2014 02:51 PM
ib516 wrote:Wes Tausend wrote:
Do you think synthetic and ordinary modern oil will perform substancially different in cold weather? The article did say synthetic flowed easier, I believe. Do you think the difference is enough to justify the extra cost?
Wes
Yes I do.
Cold pour test
Video #2
Video #3
Video #4
BenK wrote:Ben,
CR is a joke for me, but the Bible for most out there...
โMar-17-2014 09:17 AM
โMar-17-2014 07:40 AM
Wes
โMar-17-2014 07:27 AM
ib516 wrote:
1) that CR test is almost 20 years old.
2) they tested synthetic oil in an taxi cabs that hardly ever shut off and are run continuously in mild weather (not 100*F above or 40* below).
Of course it will perform about the same as regular oil.
Try repeating that test at -40* with several cold starts and see what happens.
That test was useless at determining if synthetic is any better in any vehicle but a NYC taxi - in which it wasn't, and I'd agree.
From the article:
"Big-city cabs don't see many cold start-ups or long periods of high speed driving in extreme heat. But our test results relate to the most common type of severe service - stop-and-go city driving."
I'll stand by my suggestion that if you want extra insurance against heat related break down while towing, use a quality synthetic oil.
Wes wrote:In other words I'm saying synthetic doesn't normally pay off in the family grocery getter. Unless one races to the store. But, I whole-heartedly agree with your statement,
"Lastly, an engine that is never working at extreme heat levels won't benefit from more expensive synthetic. Consumer reports did an interesting study on this."
ib516 wrote:
"I'll stand by my suggestion that if you want extra insurance against heat related break down while towing, use a quality synthetic oil."
ib516 wrote:Do you think synthetic and ordinary modern oil will perform substancially different in cold weather? The article did say synthetic flowed easier, I believe. Do you think the difference is enough to justify the extra cost?
"Of course it will perform about the same as regular oil.
Try repeating that test at -40* with several cold starts and see what happens."
โMar-16-2014 05:41 PM
โMar-16-2014 11:54 AM
โMar-15-2014 10:44 PM
Turtle n Peeps wrote:Redsky wrote:
Synthetics can be worse for engines operating under high temperatures. almost all of them are 5W40 formulations and the engine manufacturers specify this weight for sub zero driving conditions and air temperatures under 90F degrees. In hotter weather they specify a 15W40 motor oil regardless of whether it is a mineral/dino or synthetic motor oil. You do not want to be starting the engine with a 5W oil on a 100 degree day and waiting for it reach 15W to be properly lubricating the engine bearings.
You do not have any understanding on how a multi grade oil works.
โMar-15-2014 04:15 PM
โMar-15-2014 01:21 PM
โMar-15-2014 12:58 PM
sheripoms wrote:
I have a 2008 Tahoe and I am buying the B & M tranny cooler for it but do I also need a engine oil cooler? And what exactly is that?
Also If I do need one , which kind should I get?
Thanks so much in advance.
โMar-15-2014 12:26 PM
