Direct replacement for PD9140 converter?
53chevy
I searched for this with no luck. Is there a 3 or 4 stage direct replacement (footprint) for the PD9100 series converter?
Also, the Progressive Dynamics web site said to not exceed the original converter amperage due to wiring, etc. If I increased it then I assume I would need to install larger gauge cables between the batteries and converter? Thanks.
Allan
6 REPLIES 6
enblethen
Look on page 23 for wire size. Xantrex manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
53chevy
Another related question:
I'm replacing my 12V batteries with 2 GC2 6V 230ah batteries in a vented tongue box and plan to install a ~2000W or so pure sine inverter. Since I shouldn't put the inverter in the same battery box, the nearest area I can install it is about 6-7 feet away inside the trailer. Is there a way to calculate what size cables I need for that distance or is that just too far to be efficient?
Allan
53chevy
Excellent, thank you for the suggestions!
Allan
IAMICHABOD
enblethen wrote:
A direct would be the PD9245, comes with 4 stage Charge Wizard.
Charge Wizard
Best converter
Verify wire size to batteries. If large enough you could upgrade to PD9260. That would require wire no smaller then #6, but #4 would be better.
This is very true,the better upgrade is their newest PD9245C-14.8 for a higher boost/bulk voltage such as Trojan and others.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
enblethen
Charge Wizard
Best converter
Bud
USAF Retired
Pace Arrow
pianotuna
Nomad II
Nomad II
Check with http://www.bestconverter.com/
Regards, Don
