โNov-14-2018 04:27 PM
โNov-15-2018 01:50 PM
โNov-15-2018 12:18 PM
carringb wrote:Big Katuna wrote:
Only at WOT.
Ok. But if you aren't at WOT, and you need more power, wouldn't you just apply more throttle anyways?
โNov-15-2018 11:54 AM
Big Katuna wrote:
Only at WOT.
โNov-15-2018 11:38 AM
Bedlam wrote:
I don't have any metrics showing the decreased life of a street vehicle engine, but I do have experience with off-road toys riding in areas with volcanic ash or mine tailings. Those that have used KN filters, have definitely seen abnormal engine wear resulting in loss of compression, compression blow by and burning of oil. We use a two stage oiled foam filter with a prefilter dry sock over the top and still clean the filter every one or two days. My 10 year old toy engine still has strong compression and does not burn oil.
โNov-15-2018 11:36 AM
BigToe wrote:ShinerBock wrote:
Thank you TnP and rhagfo for staying on topic about if aftermarket filters actually work to increase performance, and NOT about filtration efficiency and/or warranty.
How is "performance" defined?
Especially in an RV towing application?
Is "performance" defined by a 0-60 time?
A rip roaring session on a dyno?
How long it takes to crest a grade?
A 1/4 mile drag strip run?
Or how reliably the tow vehicle can drag the trailer to a camping destination, and return back home again without incident?
What parameters truly define good performance and poor performance in a tow vehicle?
Considering the main duty of a tow vehicle, can the basic task of intake air filtration, to protect the engine so that it can return home rather than leave one stranded in a motel awaiting engine repairs, be completely excluded from towing "performance"?
โNov-15-2018 08:52 AM
โNov-15-2018 08:28 AM
โNov-15-2018 08:04 AM
โNov-15-2018 07:58 AM
mtofell1 wrote:My opinion as well.
Snake oil IMO. Little or no gain, potential damage, potential warranty issues plus the cost of buying the thing. No thanks.
โNov-15-2018 07:44 AM
โNov-15-2018 07:14 AM
โNov-15-2018 07:04 AM
โNov-15-2018 06:22 AM
โNov-15-2018 05:39 AM
ib516 wrote:
I'll tell you about my experience with K&N on my 2002 Diesel. It was properly maintained, and left not only dust in the intake tubing after the filter, but also a very fine layer of dark gunk that I can only presume was filter oil mist and dust combined on the leading edge of the turbo impeller blades which I had to remove.
It went on the local classifieds along with the cleaning kit (oil and soap spray) and I will not use a K&N ever again in any vehicle I own. I don't care if it makes 2 more hp or not. The performance gain (if any) isn't worth the decreased filtering performance (gas and diesel), risk of MAF contamination (gas), or possibly causing an unbalanced turbo that increases shaft/bushing wear (diesel).
โNov-15-2018 05:04 AM
