โMar-11-2013 05:22 PM
โSep-16-2013 11:18 AM
goreds2 wrote:lonetow wrote:explorer0863 wrote:
This article is not specific to Dodge, but it should give you a pretty good idea in what you can on your Dodge.
Click here
Here is the link for the adapter that you may need, depending on your set up.
Adapter
I hope this is helpful. Good luck!
Thanks for the tip on the adapter, I went ahead and ordered this one antennahoping it would work
Did it end up working out? Here is a SIRIUS antenna that is used on semi's. Not sure if yours is compatible or not.
Tram Sirius Antenna
โSep-16-2013 09:26 AM
Click here
Adapter
โApr-05-2013 06:34 PM
Click here
Adapter
โApr-05-2013 06:28 PM
โApr-05-2013 12:46 PM
โApr-05-2013 06:33 AM
โApr-04-2013 07:47 PM
โMar-12-2013 07:53 AM
โMar-12-2013 05:49 AM
โMar-12-2013 05:16 AM
โMar-11-2013 10:22 PM
โMar-11-2013 05:54 PM
donn0128 wrote:
Go online and buy one of the magnetic mount antennas, stick it on the front A pillar. Unplug the original one and plug your new one in. The sirius box is above and behind the glove compartment. The green plug is right in your face when you get the glove compartment dropped. On mine i had to take apart the plug in, but the antenna plugs in and works perfectly without it.
โMar-11-2013 05:39 PM
