โMay-03-2013 02:51 PM
โMay-07-2013 11:20 AM
Raften wrote:LOL Right?
Good grief, I never even knew about a wake up button and now I learn the wake up button needs a wake up itself. Way to go folks.
โMay-07-2013 06:22 AM
Pattle wrote:
Something similar happened to me. I turned everything off, and then turned off the batteries (using the push/pull button). Waited a few seconds, then turned it back on. Everything was then fine.
It seems to work like rebooting a computer.
Good luck!
โMay-06-2013 08:37 PM
โMay-06-2013 07:36 PM
Good luck!
โMay-05-2013 07:36 PM
โMay-04-2013 05:31 AM
โMay-03-2013 09:31 PM
โMay-03-2013 04:34 PM
โMay-03-2013 04:24 PM
NEOK wrote:
Is the button you are talking about the battery on/off switch just inside the door on some truck campers? From your description of a button you press to "wake everything up" it sounds like a problem in your camper 12 volt system. If it is that button and it does not light up do you have interior lights when you are not plugged in to shore power. Your 12 volt batteries in the camper may be dead.
โMay-03-2013 04:19 PM
โMay-03-2013 03:43 PM
โMay-03-2013 03:12 PM
dadwolf2 wrote:
Hate to state a possible obvious...have you put fresh batteries in the remote?
โMay-03-2013 02:54 PM
