Downside to 7' wide trailers?
memilanuk
Hello there,
New member here... about a year and a half ago we picked up our first TT, a 2000 Nash 22H that the price was right on (turns out, for a reason... ). Now we're reasonably sure that we do like RV'ing and plan on sticking with it, we're looking for something a little easier to tow with my '05 Tundra 4.7L. It does okay with the 22H as is, so long as I keep the speed down (50-55mph) and take it easy - no problem. Our existing trailer is a bit heavy, especially on the tongue, which makes it a major pita to get maneuvered into its spot in our drive (have to use a tow dolly to make the turn).
All this is leading up to... a few of the newer models I've been looking at have been similar length, add a slide-out, but are 7' wide instead of 8', and seem to be a fair bit lighter all around in dry weight/ GVWR/ tongue weight - enough so that the Tundra should be able to pull it with ease, and seeing 'around' the trailer should be (hopefully) much easier. I realize that a foot is a foot is a foot... but with a queen bed up front, turned length-wise instead of side-ways (like in the Nash), and a fully enclosed rear bath, and a tipout couch/dinette - i.e. everything we really want/need... what am I missing here? *Is* there a significant downside that I need to be aware of?
TIA,
Monte
13 REPLIES 13
skipnchar
I have significant doubts that a heavy tongue would have any effect on maneuvering and loosing a foot of width will not make a HUGE difference there either. I think if those are your issues what you REALLY need to do is buy a good set of tow mirrors and practice maneuvering. Of course EVERYONE always finds it a good idea to buy a new trailer 🙂 If that's you goal then go for it and enjoy it.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
rightyouareken
Our trailer is 8' (96") wide and has a 60"x74" bed lengthwise in the front of the trailer. This is sometimes called a walk around bed since you can walk around either side of it to get in. There isn't a ton of room on either side in our trailer (18" on each side doing the math... 96-60 = 36/2 = 18"). With a 7' wide trailer you'd reduce that quite a bit. Looks like it would leave you maximum 12" either side of the bed, maybe even less allowing for the thickness of the walls. Any wardrobes next to the bed would also be smaller. Might be pretty tight.
2012 Ford F150 FX4 5.0 3.73 SuperCrew Short Bed
2013 Jayco JayFlight 24FBS, Equal-i-zer 1k hitch
Campfire_Time
Our previous HTT was 7 ft wide and 17 ft long. As someone said, not much room to pass on the inside. The new HTT is 8 ft wide and 21 ft long. Aside from about a 1mph drop in mileage I notice no difference in towing, which really surprised me. I thought I would feel a major difference because of the additional frontal area. Without a slide I would not consider a 7 ft wide trailer again.
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
JiminDenver
You will notice it when trying to pass one another inside, and it may have a effect on the cabin fever feeling when it rains. We have a narrower trailer w/o a slide and I'd take more comfortable seating over more room any day.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
Redterpos3
We are in the middle of our 2 1/2 week trip with our 2011 Nash 27T. Ours is 8' wide. When we were looking I noticed that some trailers were going to 8.5', and I didn't want to go wider than 8', especially with being new to towing. I didn't realize there were 7' ones. If it has a slide you probably won't notice, and it would be nicer to see backwards in your mirrors, i would think. Maneuvering may have to do with length. People here say the longer the trailer the easier it is to maneuver. My 30' seems to do well for me. I was even able to back up at a rest area where the trucks pull in back to back, and the one in front of me hadn't left yet.
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
Francesca_Knowl
Dropping that foot of in-transit width brings with it significant gains in aerodynamic efficiency.
Trailer frontal area is the main factor governing drag, and reducing width by one foot represents an automatic improvement of more than 10%.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
PAThwacker
7FtX21FT bh htt. easy to tow, opens up on the front and side for the nonMRI effect.
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
Jayco254
Not all 8 footers have the bed length-ways although an 8 footer will give you a longer bed even cross-ways than a 7 footer. My wife would rather sleep on the couch than the bed so the cross-ways bed works for us. If you can work out something that is comfortable for the two of you, you've' got a good trailer, as long as your Tundra isn't straining too bad I'd keep what you've got, you know what it is. I like my Jayco but a Nash is a good trailer. And you can get a lemon in any brand.
Tom, Kathy, Nikki, & Kelly
Pets: Lady - Texas Heeler, Dinger - Rhodesian Riidgeback Mix
2008 Ford Expedition Eddie Bauer 4x4 5.4 ci 3.73 gears
2008 Dodge Ram SLT Big Horn 4x4 5.7L Hemi 3.92 gears
2007 Jayco Jayfeather EXP 254
Husky W/D, P-3
memilanuk
Thanks for the replies, folks.
The Nash we have is a solid unit - everything works - but the more I look around it, the more I'm convinced someone a couple owners back must have wrecked it - literally, possibly even flopping it over on one side. There's been a lot of 'fixing' done on it, but still some structural concerns that I didn't notice before. It's still sound - I pulled it from Washington state to northern New Mexico last summer, and will do so again in about four weeks unless I get something newer before then. For the most part I can't honestly believe I *missed* much of what I've either fixed thus far or have on a list for if we keep it... but needless to say I'll be giving the next RV we look at a *lot* closer scrutiny!
I think Bruce kind of hit on what I was hoping for... that having the slider would make up for the lack of width when inside, as well as being easier to tow.
Bruce_H_
We have a 7' wide trailer and we love it. 7' is so much easier to tow than 8'. It has a large slide and windows on all 4 sides, and feels quite spacious for such a small trailer.
But it has a queen bed cross ways in the front. Would be nice to have the same trailer stretched so that the queen bed ran north and south. I am not aware of any 7-footers with such a bed arrangement.
Bruce
2012 Lance 1575 TT pulled by 2013 4WD Expedition with HD Tow Package
APT
Downside? The Nash is a well built TT, and pretty much anything else is not designed/built as stable. They are still good enough for most RVers.
Size wise, a foot narrower, but gaining a slide will feel probably bigger.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
boosTT
I also agree. My trailer is 8.5' wide now.... thats like small slide on the entire length of the trailer.
JJBIRISH
whatever turns you on… it is an individual thing…
I would feel like I was camping in an enclosed MRI with the 7’s that I have been in…
I would be willing to give up some length but no width…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
