Nov-03-2013 02:39 PM
Nov-04-2013 04:36 AM
Nov-04-2013 04:16 AM
steve68steve wrote:Buzzcut1 wrote:
At idle, the Power Stroke diesel burns approximately .5 gallons of diesel per hour which is significantly less than many RV generators at full load."
that is flipping nuts. $4/ hour or $32/8 hours to run a generator if the fuel is at Ca prices of around $4.00/gallon. I'll take the Honda 2000 using two gallons of $3.75/ gallon gas to run flat out for 8hrs. And not coke up my engine
You missed the "1/2" in your calculation - it's $2/ hour. It may cost only $7.50 to run a Honda 2000, but it also costs $1000 to by it. You'd have to put quite a few hours on it until you started realizing a savings over idling diesel (provided your diesel was already set-up to charge).
Big diesel engines (trains, ships, back up power generators, etc.) run/ idle continuously - or at least used to, unless they're brought down for service. Idling is child's play for a diesel.
Nov-04-2013 02:45 AM
Nov-03-2013 08:15 PM
Nov-03-2013 04:18 PM
Nov-03-2013 03:13 PM
Nov-03-2013 03:05 PM
