E-350 - How to pack the back?
Redterpos3
2013 was our first year towing with our van. I gathered all the necessary gear and basically just kept putting stuff in to the back,with the things I need first closest to the rear, and so on. I am wondering if anyone has a better way of packing, a system, series of boxes, etc. For the trailer I have found a great way of packing things into the pass through, so that I've figured out well. Now I'm trying to think of better using the back of my van.
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
8 REPLIES 8
Jarlaxle
If you remove a seat, the mounts for it make GREAT tie-down points for your gear.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. 😞
Current rig:
1992 International Genesis school bus conversion
Redterpos3
Lessmore wrote:
Whatever packing system you use in a van....make sure that the weight is evenly distributed and if carrying heavy items, just don't put it all on the tail end....remember if you have to hammer the brakes on hard....ensure that when you packed you van....you packed it in such a way that large 'packed' objects do not come flying through the inside of the van and hit passengers.
I'm not going to say how I learned this...I just learned it !
OK ! ;):B
Thanks for the reminder!! I am learning that packing lesson!! That's part of the reason for my original post, trying to figure out the best way of keeping everything put, and in place when I need it!
2018 yr6 4nts 30m
Lessmore
Weight distribution is a concept I developed when I drove commercial vans and trucks...way back when, while paying for U.
Another factor to consider is to remember if you have to hammer the brakes on hard....ensure that when you packed you van....you packed it in such a way that large 'packed' objects do not come flying through the inside of the van and hit passengers.
OK ! ;):B
Redterpos3
JBinOR wrote:
In our Chevy 3500, many take out the back seat for storage, I presume you did the same, but we took out the front bench seat, making it much easier to get to the things we need right away.
I've tried it both ways. I take out the 4th seat, and then either the 3rd seat, giving large space in rear, or I've taken our 2nd seat giving me room up front. I do this if the dog is traveling also. Not sure which way I like best, still trying to figure out what is the best way to pack.
I did find the Black/Yellow bins at Home Depot, picked up 4. They seem very sturdy! Will begin to practice packing after I stop using up all my energy blowing/shoveling snow!! Though it is kinda nice having snow on the ground while watching the Winter Olympics. It can all disappear when the olympics are over, however!! :W
2018 yr6 4nts 30m
JBinOR
1999 Chevy Express 3500 5.7L
Jayco 26BH
Redterpos3
carringb wrote:
Plastic totes. Specifically, the black ones with yellow lids from home depot.
That does look like something that would work!!! I'll look into something like these! Thanks for the idea!
2018 yr6 4nts 30m
APT
Something that looks like the picture carringb posted is available at Costco for about $8ea. They rock!
2017 Subaru Outback 3.6R
carringb
Plastic totes. Specifically, the black ones with yellow lids from home depot. Rubbermaid, including the high-$ Action Packer series, get soft when warm which means you can't sit on them without crushing, and sometimes the lids won't even stay closed. Sterilite is much stronger but if you drop one while its cold, it'll shatter. These guys are tough all the way around, and the lids are slotted in case you need to cam-strap them to the roof. The deep lid also means they stay stacked in the back of the van.
2014 ORV really big trailer
2015 Ford Focus ST
