Since 2007 or so Outfitter went with a power roof that uses a modified jack motor. The motor is mounted at the end of the mechanism's screw drive. It does make working the roof effortless but also MUCH slower. No pictures as I would need to disassemble part of my camper to get them.
If you go with a drill ENSURE the drill has a low-speed/high-torque setting and that the drive gear is fully meshed as you will quickly wear it out otherwise.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
